Youtuber published on Feb 6, 2015 new version of that car landing video:I wonder if Elon Musk was inspired by this Heavy Metal film with a 1959 Corvette Roadster in space?
View attachment 278517 View attachment 278518
______________________*******
Air pressure at F9 1. stage separation is so low that liquids boil as in vacuum. Extra altitude will make no difference.I don't know, it was just an additional possible answer. We aren't sure if they didn't load enough because it burned more than expected, or if it boiled away, or if it froze and wasn't available to use.
I'm sure we'll get the answer eventually but I'm holding onto the boiled away hypothesis until I hear otherwise.
Oh, ok. I thought you had heard the answer.
I was confused how that could be since the 2nd stage can relight after 6hrs in space and the TEA TEB has to be sealed from the atmosphere.
The Saturn V center had the same problem for Shuttle launches off of 39A. The FSS and RSS blocked the view until the stack cleared them. While there's not much left of the RSS, the FSS is still there. With commercial crew on the horizon for 39A, the FSS will probably be there as long as F9 flies from there. Saturn V center's view of 39B is a bit better since B is 1.66 miles Northwest of 39A.Back from Cape Canaveral after a great day under the sun yesterday. 'Feel the Heat' was very well organized by NASA.
Except I have one big gripe, and I think that ruined the whole thing. This location is simply the worst location you could pick for this particular launch. This was exactly side-on from the rocket and on top of it the transport-erecter completely obscured the view while the rocket was in the pad. Even after lift-off, since FH was only side-on we could only see one stick. WTF? it was almost as if we were watching a Falcon 9 launch. Even from a distance perspective I believe there were other public viewing areas that were closer.
For those of us with AP2.5, we can sympathize that Starman is no longer in the correct orbitLive Views of Starman
Awesome video of the boosters landing:
One of the best launch audio recordings I've heard. About as close to being there as it gets.
Here's a video taken from "Feel the Heat" and I can see what you're commenting about.
That was the best of the best continuous footage from the ground.Here is the best video of the launch. I would even say it was better than the broadcast. Very cool.
That is my favourite video of all!Awesome video of the boosters landing:
I don't buy that it was a normal style leak from some manufacturing defect. That system hasn't changed and they haven't had a failure in it in 20+ landing attempts (other failures yes, just not TEA/TAB ignition issues).
I have to think it is due to the nature of the maximum altitude of the center core causing a temperature or pressure issue.
While the 2nd stage can relight after 6 hours in space the 2nd stage has always been expected to function in space. Stage 1 has always been expected to function in atmosphere. No stage 1 has done what the center core did before yesterday.
Heavy (center core), meco ~88km, separation ~91km speed at separation ~9500 km/h
Iridium 4 (stage 1), meco ~75 km, separation ~78km speed at separation ~7300 km/h
https://i.redd.it/cvo84so8aefy.png has some other first stage altitudes and you'll see most separate between 60 and 70 km.
edit: https://i.imgur.com/NezZ0Qf.png shows stage 1 continuing above 100km in a couple of cases. So that goes against my theory about altitude.
https://i.redd.it/15p6ll4zjrvz.png is another rev of the combined content.
Check out latest video from SpaceX.
At 29:50 all three engines are lit. A few seconds later the bottom one is out and the top is weak.
So it looks like TEA-TEB was not the issue (all three running). Possible turbo pump failure on one causing SW to shut down the other to balance?
In a couple other landing clips on his channel (also pretty good), he mentions he's shooting from LC-37B, the Delta IV pad and you can see LC-34 to the South in the foreground. Last I saw, LC-17 is closed and fenced off.The video I posted of the landing:
I'll bet the people took this video from SLC-17. They seem to be up high. Maybe they are on one of the old launch towers from the Delta II.
Cape Canaveral Air Force Station Space Launch Complex 17 - Wikipedia
Final burn though? That time is just over a minute away from reaching the drone ship.Check out latest video from SpaceX.
