Falcon wing door catching trim and ripping it up
Discussion in 'Model X: Interior & Exterior' started by ebjohnso, Oct 16, 2016.
  1. ebjohnso
    ebjohnso Member
    Lake Mary, FL
    Got my x60 on thursday. Everything has been amazing on it. On Saturday the falcon wing door started catching on the trim above the back window. I'm taking it in Monday/Tuesday but wondering if anyone had something similar so I can tell my service center to hopefully fast track the process
    • Disagree x 1
  2. mal_tsla
    mal_tsla Member
    Austin, TX
    This seems like a pretty common problem -- I've seen a lot threads about it in the past month. When was your X built?
  3. ebjohnso
    ebjohnso Member
    Lake Mary, FL
    End of Aug/ early September
  4. EV-lutioin
    EV-lutioin Active Member
    Wow, I have never seen that before. The FWD's on my March/April build MX have been flawless. I hope your Service Center can get this resolved for you quickly.
  5. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    Your door gap actually looks pretty good. I wonder if the trim piece got stuck on incorrectly? I actually have a few places were my door gap looks tighter and it clears OK.
  6. Spidy
    Spidy Active Member
    EU
  7. ebjohnso
    ebjohnso Member
    Lake Mary, FL
  8. outie
    outie Active Member
    SoCal
    Yes I was one of the first to have this issue. Seems like it started with cars built in September. Mine happened during delivery. Check the seal/gasket on the door itself it's probably torn too. They will fix it and I haven't had any issue since the fix. Good luck.
  9. Danieljk
    Danieljk Member
    Montreal, quebec
    They found the same issue when mine arrived but fixed both in a couple of hours before delivery and all was good. They simply removed the rear windows and moved them back a hair to clear the moldings.
  10. vv132
    vv132 Member
    NJ
    Same thing started happening on ours last week. Trying to get the SC to look at it.
