Falcon Wing Door hit parking garage roof - normal?
Discussion in 'Model X' started by dckiwi, Feb 14, 2021.
  1. dckiwi
    dckiwi Member
    Reston, VA
    I opened the falcon wing door on our month-old Model X in a parking garage this morning. It swung up and hit a concrete section of the roof above. Fortunately the damage was a single tiny paint chip.
    How can I test whether the sensors are working correctly on this door? The same door tried to close when my daughter was still standing under it a couple of days earlier. Are there some tests I can try at home before scheduling service?
    For example, I tried holding a broom above both doors. In both cases the doors swung up and hit the broom, so I'm thinking that's not a good test.
  2. jboy210
    jboy210 Supporting Member
    Northern California
    If you look at the section between the falcon wing doors you can see the sensors. It is possible for them to miss an obstruction protruding from the ceiling away from the center of the car like a low hanging pipe.
    I believe the later cars have additional sensors to prevent closing on objects.
  3. dckiwi
    dckiwi Member
    Reston, VA
    I actually think it was this ‘known’ issue:
    There was a pillar running across the top of the garage, and it didn’t extend to the middle of the garage.
    So the top sensors don’t see it. Anyone else have this issue?
    • Informative x 2
  4. Tam
    Tam Well-Known Member
    Visalia, CA
    My thinking is: It's just like "Autopilot" that requires humans to monitor the environment and to intervene as needed.
  5. TespaceX
    TespaceX Member
    Yup. We never just open the FWD assuming it will stop properly by itself. We always have a finger ready on the screen or the switch just in case. But, it can be frustrating because sometimes the door opens very fast and sometimes very slowly (and then stops too soon), even when parked at home in the exact same spot.
  6. Need
    Need Active Member
    SoCal
    Our MX FWD had whacked my wife's many times when our kid got out fast and pressed to close as my wife was existing the passenger side. I don't think there is any good sensor to prevent whacking. Human just had to learn to stay clear of FWD when it closes.
    As for opening the FWD inside garage. I found that the car seems to know you are in a low ceiling garage regardless of the location of the ceiling beams. Anytime I am in one of those garages, the FWDs and Trunk will only open a tiny gap even if there is plenty of space above. We have to override to open it more or just use hand to push them up manually.
  7. VikH
    VikH Supporting Member
    Midwest, USA
    "Normal". Parking garages are FWDs worst enemy. When in parking garages, you need to get out of the car and watch the doors open. Have the fob in your hand ready to stop them.
  8. VikH
    Midwest, USA
    +Late 2017 MX cars have an ultra sonic sensor on the interior of the FWD (behind speaker grille) to prevent head bonks.
  9. gmontem
    gmontem Model S P01707
    Castro Valley, CA
    I guess these ultra sonic sensors still aren't up to the task.
  10. DCGOO
    DCGOO Active Member
    Indianapolis, IN
    There is only one topside sensor. Center of the roof between the doors. In a structure with a complicated ceiling, it sometimes misses nearby obstructions.
    My garage at home has 14 foot high ceiling (to accommodate an RV). I had a helluva time getting the "Always fully open at this location" to trip. I finally had to partially close the garage door, then position the sensor directly under the partially closed door. Finally got it to ask the fully open question. My point is, that sensor does not always "see" nearby obstructions.
  11. elguapo
    elguapo Supporting Member
    Maryland
    Topside issue is as others mention.
    Other issue is NO sensor other than pressure/touch for when the FWDs come. So as others have said, the doors will come down and hit kids on the head. Then stop. It’s unpleasant.
  12. Dechidus
    Dechidus Member
    New Jersey
    I wish the fwd worked like in the demo when they first announced it. Open up even when there is a car close to you but at a tighter angle. In reality it just stops when it detects anything close lol
  13. VikH
    Midwest, USA
    Better than nothing. My car does not have the interior ultrasonic.
  14. jboy210
    Northern California
    Mine works as advertised. If I park next to a vehicle and open the door, it cracks open and raises the door up close my car before extended the door to let a person in.
  15. outie
    outie Active Member
    SoCal
    When you are inside a parking garage, ALWAYS open the FWD from the outside so you can observe the outside environment and prepare to stop the door with YOUR HAND (the fob is too slow when you react). There are many, many obstacles the sensors won't see, like a beam or pipes that regularly show up in parking garages.
    I have also been in a parking garage with smaller spaces with slanted parking spaces and the door would've hit the adjacent car's side mirror if I didn't stop it in time.
    127.0.0.0 Member
    Are there going to be any new sensors for the Model X Falcon wing with the refresh model or improvement ?
  17. elguapo
    Maryland
    No one knows, but I would be shocked if they touch the FWD. It took a long time to get them to work the way they do now. They’re “good enough” in Tesla’s book. Honestly, I am surprised they didn’t dump them in the refresh. But I love them, so I am happy!
  18. bikeandsail
    bikeandsail Member
    United States, NE Ohio
    I believe the technology only works well for continuous objects IE flat ceilings etc not line objects like broom handles. I believe the manual even says that.
