Yes, it’s a 2021 refresh MSLRDoes your S have the new in-cabin camera with the IR illuminator on it?
Would be nice if Tesla had a legitimate portal for this stuff. Not just aimlessly pressing a button and hoping they know what you’re reporting and why, or whether they will even look at your report.For those of you who are getting false positive strikes from the cabin camera, you should email fsdbeta at tesla dot com and request that cabin camera data be included in the AP snapshot. that way you can report these false positives and they have a chance at pinpointing the issue. I see no way for them to even realize a problem unless they collect data on the false positives.
-edit-
might be easier said than done since there's some privacy concerns about cabin camera leaving the car (and normal snapshot data IS tied to VIN). but having yet another button on the UI just for cabin camera issues seems unlikely/untenable.
I'm getting this quite often... where it stops recognizing all inputs, wheel torque, volume change, speed change... and often I just have to just take over or disengage with the stalk.In all fairness, occasionally, my car stops recognizing wheel input and start nagging with no amount of tugging effective. I've learned to simply disengage FSD and reengage it. That always clears up the problem. Hard to do that in the middle of a turn though!
If it's failing to recognize even volume wheel changes, there is a problem with the vehicle. It's either hardware (the steering wheel needs adjustment or replacement), or software (there is a bug in your firmware and you might need the firmware forced back onto the car by service). In either way, you'll need to open a service ticket and have a tech take a look at the car.I'm getting this quite often... where it stops recognizing all inputs, wheel torque, volume change, speed change... and often I just have to just take over or disengage with the stalk.
Without cabin camera I only have 3 strikes, and I the wheel nags are way more frequent than if the car has cabin camera.
This is a big problem because I want to pay more attention to the road rather than looking at the screen, and one would think I should be ok as long as I keep some torque on the wheel.
Unfortunately no, because it often stops recognizing wheel input, so I have to constantly look at the screen to make sure it's recognizing my hand on the wheel.
Does anyone know how much time from the "Apply Slight Turning Force to Steering Wheel" message to a forced disengagement/strike?
I'm guessing probably 10-15s
Problem is that it's not every time, it's totally random... it will recognize any input (wheel torque, volume, next song, speed change etc.) 9 times out of 10, but occasionally what I described in my previous post will happen.If it's failing to recognize even volume wheel changes, there is a problem with the vehicle. It's either hardware (the steering wheel needs adjustment or replacement), or software (there is a bug in your firmware and you might need the firmware forced back onto the car by service). In either way, you'll need to open a service ticket and have a tech take a look at the car.
If it happens, press the voice command button and say "big report". That will save a file that the techs can access to check the car. Note the date and time for the tech.Problem is that it's not every time, it's totally random... it will recognize any input (wheel torque, volume, next song, speed change etc.) 9 times out of 10, but occasionally what I described in my previous post will happen.
Also doesn't seem like I'm the only one as I was quoting @Supcom post. He doesn't mention other inputs, but was that attempted?
As with most random problems, it's nearly impossible to troubleshoot if you don't know when it happens.
They would try it a few times, and tell me it's working fine.
In my case, when this happens the nag nanny does not recognize radio volume control either, though the radio volume does respond. So, there appears to be nothing wrong with the steering wheel - especially since disabling and re-enabling whatever self-driving mode is active always fixes the problem.Problem is that it's not every time, it's totally random... it will recognize any input (wheel torque, volume, next song, speed change etc.) 9 times out of 10, but occasionally what I described in my previous post will happen.
Same, volume and speed change inputs work, but the nag doesn’t go away.In my case, when this happens the nag nanny does not recognize radio volume control either, though the radio volume does respond. So, there appears to be nothing wrong with the steering wheel - especially since disabling and re-enabling whatever self-driving mode is active always fixes the problem.
So, no need to write a service ticket. Nothing for a tech to fix.
When it happens, immediately push the stalk up to go to manual driving. Then re-engage AP/NOA/FSD and all will be fine. You won't get a strike unless you keep fighting it until the nag gives up on you.Same, volume and speed change inputs work, but the nag doesn’t go away.
if I get a strike because of this bug I’m going to be really upset.
Similar experience for me. I had only one (screaming kids caused me to miss the warnings, mea culpa) in all the months of beta. Now on 10.12.2, I have 3 new ones, none of which seemed “normal”. Got one today, looking straight ahead, hand on the wheel, no warning at all. It’s a little nuts.Figured there would be a thread about this. I have been in the FSD Beta program for maybe seven or so months now. Have never gotten a strike for not paying attention. We have Tesla insurance and solid 98-99 safety score. Downloaded 2022.12.3.20, what, maybe two-three weeks ago and have 4 of 5 strikes already. Have no idea why it's happening. Driving down the highway, eyes on the road. at least one hand on the wheel, BAM...flashing red light and strike. Happened to my wife while I was in the passenger seat and we were both perplexed. Pulled over to reset and then it happened to me, seemingly out of the blue. Something seems different with this aspect of the sw/update. The beeps are different, or absent, or timed differently. We're about to get booted, and there's no way we should be.
Why is this happening?? We didn't spontaneously change how we drive, from seven or so months of no strikes to four in a few weeks? That's absurd. The only variable that seems changed is the sw update. Debating whether to email Tesla now and discuss this, or wait until what seems to be the inevitable 5th strike and then appeal?
yes, but a "bug report" does not go immediately to tesla (at least not in current versions). It will only be seen (MAYBE) by the service department when taking it in.If it happens, press the voice command button and say "big report". That will save a file that the techs can access to check the car. Note the date and time for the tech.
Correct, as I said it's for the service techs. You say "bug report" and it will show the report saved. You then open a ticket for service (mobile or service center) and let the tech know you have a bug report they can examine.yes, but a "bug report" does not go immediately to tesla (at least not in current versions). It will only be seen (MAYBE) by the service department when taking it in.
Then there are those who have issues so bad it's unusable: Strikes while looking straight ahead with both hands on the wheel, strikes with zero warning, etc.
This is exactly what happened with at least two of my strikes. Immediate strike with only one blue flash.
The new 10.69 is rolling out slowly - it will catch you up to most of the general code. If you absolutely must have the general code, you can send an e-mail to fsdbeta @ tesla.com from the e-mail address associated with your Tesla account asking to be removed from FSD Beta. Send it a few times (2-3 should do it), but don't expect a response. In a few days or possibly a few weeks, your car will suddenly say you have a software update available and it will be the general code version with FSD Beta removed.There's too much coincidence in these experiences. Post #37 seems to hit close to the mark on likely scenarios. What I've also realized is: I can't easily opt out of the beta can get caught up with everyone else's non-beta software level, (what are they up to, 2022.20.x now?) So we're caught in limbo on 2022.12.3 without the ability to play with FSD beta while also not enjoying updated features like independent streaming profiles and other improvements. Love us or let us go, Elon!
