Fancy new trim??
selfbp
349
359
East, TN
Has anyone got any insight if it’s possible to swap the aluminum/ silver interior trim for the new Gunmetal/ grey trim? I assume it’d be a complex process from the door trim being implanted in the panels.
I would think most of the trim pieces are on Tesla’s catalog...
Reactions: viper2ko
WASD
191
129
Mission Hills
I just got a loaner 75D while my P90D is in for a few fixes. I would love to do this as well. I'm guessing it would probably be easier/cheaper to vinyl wrap it though.
Terra117
133
17
Edina, MN
I’d buy a can of plati dip and do it myself.
Replacing the panels I’d be worried that a rattle will pop up from a loose piece of trim
I've removed many panels over the years as a DIY'er. The plastic clips every manufacturer uses seem to hold the panels slightly less tight after going through a removal/reinstall cycle. I learned early on to replace all of them when you take a panel off. It avoids the worst case scenario of getting a rattle and having to pull it again just to replace one or more clips. Also, they can be rather fragile, so one or more are likely to break when coming off. You need to have a couple spares on hand for that situation anyway.
Reactions: selfbp and AMPd
That's my experience, too. In fact, the door trim panel clips that are used on Model S and X (not sure about Model 3) are one time use and Tesla says to replace them any time that the trim panel is removed.
