Faster Supercharging
Discussion in 'Model S: Battery & Charging' started by JPUConn, Sep 8, 2016.
  1. JPUConn
    JPUConn Member
    CT
    Plugged in for a quick juice up at West Hartford CT supercharger and immediately got to 341 mph / 103 kWh with AC on. After a few minutes it dropped to the usual 90 kWh I get at this location.
    I've charged at this location a handful of times with similar conditions and battery level and never been over ~90 kWh.
    Is tesla testing out ramping up the supercharger speed?
  2. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    Many factors in place...was anyone on the paired charger you used? What type of battery (you probably don't have an A battery).. What was percent soc when charging in the past?
  3. EVie'sDad
    EVie'sDad Member
    Newark, CA
    I got 370 mi/hr charge on Monday in Napa, no one else was there and that is the highest i have seen, but it was about 6:30pm PST in about 87 degree weather, we did have the AC going but on very low, with Range mode on and about 90 miles remaining in the battery.
    I have seen between 182 and 370 mi/hr, but more commonly between 240 and 340 mi/hr charging, which then begins to ramp down as it gets closer to topping off.
  4. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Reporting mph rates isn't really helpful, as it's an average over the session. Better to report charging in kW as that is the instantaneous power-- you can either change the display to show it or just multiply the V x A.
    • Helpful x 3
  5. EVie'sDad
    EVie'sDad Member
    Newark, CA
    Values seen by me in Napa were 373 mi/hr, 293 A, and 370 V.
  6. silentsnow31802
    Napa, Ca
    Highest ive seen to date was 303A at 371V at the Petaluma, Ca supercharger. It was about 9:30PM and I was the only one there.
  7. apacheguy
    apacheguy S Sig #255
    So Cal
    @JPUConn - Please take a picture of the battery label sticker under the front passenger wheel.
  8. andrewket
    andrewket Well-Known Member
    You mean kW, not kWh.
  9. JPUConn
    JPUConn Member
    CT
    B pack
  10. apacheguy
    So Cal
    Hmm. Then it is very odd that you do not normally see rates above 90 kW.
