Faulty Mobile Connector?
Discussion in 'Model Y: Battery & Charging' started by JLOC, Mar 2, 2021 at 10:20 PM.
  1. JLOC
    JLOC Member
    Orange County, CA
    My Model Y was just delivered Monday, March 1st, and it charged normally the first night. However, on night 2, I plugged the mobile connector into the charge port, and I hear a number of clicks before the T turns amber in color. The Tesla app tells me "charge cable may not be plugged securely into the vehicle," and the car is also displaying an error.
    However, the car is charging, albeit at 16 miles per hour, v. the 32 it charged at last night. I tried unplugging and replugging the mobile connector (and I checked for any debris), and I tried a second NEMA 14-50 outlet at our home, both with the same results. My sister uses our outlets when she comes to visit, and she has never had an issue with her mobile connector, so I am wondering if I am dealing with a faulty mobile connector?
    I already have a service appointment for Thursday (to have homelink installed), so I've updated my appointment to advise of this new issue.
  2. srlawren
    srlawren Member
    Vancouver, BC, Canada, Eh?
    I have read here in the community that the charge port can be very tight when the vehicle is new, and you have to insert quite firmly to get it fully connected.
  3. jcanoe
    jcanoe Active Member
    Maryland
    Make sure that the NEMA 14-50 power plug pigtail is fully inserted into the Mobile Connector chassis. Also, don't leave the Mobile Connector chassis hanging, supported only by the power plug connector.
  4. JLOC
    JLOC Member
    Orange County, CA
    Thanks. First, I did check the 14-50 power plug pigtail was fully inserted, and I did make sure the charge port was all the way in (and I did put additional pressure to see if that would help).
    Second, I do have the mobile connector chassis supported by a Tornado U hook, so that the chassis is not just left dangling. I also have one of those cord organizers to wrap the cord around.
    Third, when I got into the car this morning, the car was charged, although I was getting the error "regenerative braking temporarily reduced. Regen will increase as vehicle is driven," and I got the error code DI_a201. Not sure if the regen issue is related to the charging issue.
  5. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    What level did you set the car to charge to? 100%? 90%? Something else?
  6. JLOC
    JLOC Member
    Orange County, CA
    Charge level set to the maximum level for "Daily," which I believe is 90%.
    Not sure if it makes a difference, but I live in Southern California, and temperature was in the 50's this morning.
  7. MorrisonHiker
    Colorado
    Charging to 90% should be fine. I just wanted to make sure you weren't setting it to 100% unless you had a long trip planned.
    The regen reduced message would've been due to the colder temperature.
  8. jcanoe
    Maryland
    The message re reduced regenerative braking is because the battery pack was not warmed as it would be if you had preconditioned the vehicle for ~20 minutes.
    The next time you charge the Tesla check the charging status screen. The screen will display the charging voltage and charging amperage in real time. You should observe the charging voltage at 240V (+/- 5 volts) and 32 amps once the charging ramps up to the 32A limit of the Mobile Connector w/14-50 power plug.
  9. JLOC
    JLOC Member
    Orange County, CA
    Thank you! I've got a mobile service coming tomorrow anyway, so they will check on my charging issue for me as well. Thanks again for your help!
  10. JLOC
    JLOC Member
    Orange County, CA
    The mobile service technician initially thought I had a faulty charge port, but it turned out to be a bad mobile connector. He switched it out and everything looks to be working as normal again. Hallelujah.
    • Informative x 2
  11. jcanoe
    Maryland
    Glad to hear that the source of the problem was just the Mobile Connector.
