Favorite options? I want a snowplow and a winch.
Discussion in 'Cybertruck' started by OConnorStP, Nov 22, 2019.
  1. OConnorStP
    OConnorStP Member
    Praag, WI, USA
    Pickup trucks are all about the stuff you'd be wanting to add.
    Me, I want a snowplow and a winch in the worst way. I have 3 options for clearing my road. This is a picture of the only one the Cybertruck *couldn't* replace. Instant start, heated cab. Get on it you peepul.
    • Like x 6
  2. Dazureus
    Dazureus Member
    Michigan
    Battery weight means that you won't need to carry sand bags in your truck bed during winter time.
    • Informative x 2
  3. Lasairfion
    Lasairfion Member
    UK
    I was surprised not to see a winch on the front. My attempt at guessing the design had one built into the front, under the headlight.
  4. OConnorStP
    OConnorStP Member
    Praag, WI, USA
    Yep -- that's the big problem with my smallest plowing option (Ranger EV with a blade) -- too light.
    Seems like the perfect spot -- and terrific if Tesla added it to the AC outlets and air-compressor already on board. But an aftermarket winch would be OK too.
  5. Gwgan
    Gwgan Almost a wagon
    Maine
    Dual +1 motor with a winch motor but with no frame where does the winch attach?
    If this can plow it will replace my Tundra.
  6. cdeleo
    cdeleo Member
    New York
    Yes I also want to know if a plow is possible. A must for me. Or maybe a front mounted pto snow blower ;)
  7. ThomasD
    ThomasD Member
    florida
    Under rear seat full length lockable storage Able to turn off traction control. Overhead console with map lights
  8. Top Secret
    Top Secret New Member
    The High Desert
    I posted on Twitter,...
    A rack in the bed where a custom truck oriented powerwall or two could be slid in for excessive range capacity enhancement.
  9. mongo
    mongo Well-Known Member
    Michigan
    Ideally, the plow would integrated with the truck systems so that it can automatically lift when you select reverse and drop when you select forward.
  10. ohmman
    ohmman Plaid-ish Moderator
    North Bay, CA
    I feel like a PTO would be extremely useful, especially since it could be controlled separately from the truck.
  11. sparcs
    sparcs Active Member
    #11 sparcs, Nov 24, 2019
    would be awesome if Tesla could program the cybertruck to plow without a driver in it. your driveway gets plowed on its' own. Get a fleet of these and mint money.
    RoboPlow instead of RoboTaxi. Probably happens after i am long gone from this earth, but it's nice to dream.
    • Like x 5
  12. mongo
    Michigan
    Except there is no constantly running engine to TO the P from. Need a HV or 48V sourced hydraulic pump or such.
  13. ohmman
    North Bay, CA
    OK, so logically speaking it wouldn't be a PTO. It would be a PTO simulator that was separately controlled. But I would think it would be an electric motor - is there a reason it couldn't be? A dedicated electric motor for a PTO seems like it would be awesome.
  14. mongo
    Michigan
    Agreed. I'm just wondering built in or separate. It might be like the combo tools that have one power head for many attachments. Or say 3 different sized power units. Could have a hitch mounted backhoe, snowplow, sweeper, snowblower, front end loader.
    The plow truck I just disposed of had its own hydraulic pump that ran off 12V. A motor out might be the best option. No hydraulics with the truck and no high current electrical connections.
  15. Sasmania
    Sasmania Member
    Scottsdale & Flagstaff AZ
    OMG!! I totally want to get a Snow Plow for my CyberTruck! I run vacation rentals in Flagstaff and there's a big storm right now and I feel helpless relying on other people to dig my guests out of the snow. Would be so fun to do it myself with this BEAST of a truck! I have zero experience with snow plows.... so what does the truck need to be able to able to attach a legit plow to the front?
  16. Electruck
    Electruck Member
    WI
    #16 Electruck, Nov 29, 2019
  17. keeney
    keeney Member
    Minnesota
    Plows beat up trucks bad. Even HD 1-ton trucks with heavy frames get tweaked when you hit a snowbank a little harder than planned. That said, I am sure somebody will adapt some of the light duty plows to fit this truck.
    A snowblower the width of the truck is going to need 30 or 40 hp of sustained mechanical power to be effective. Its also going to a big heavy thing on the order of a few thousand pounds, so the truck will need a lift mechanism up front and some beefy front suspension. Not something you really see too much of except maybe on the front of a 5 or 10 ton dump truck. Even those might have their own diesel engine self contained in the blower.
  18. David99
    David99 Active Member
    Brea, Orange County
    If you need your own snow plow, you live in the wrong place. LOL
    • Disagree x 2
  19. Shocker
    Shocker Member
    Michigan
    In this location a snowplow is a bulldozer. Where I live the snowfall is a small fraction of this but I never see a light duty pickup with a blade. HD's only.
  20. cdeleo
    cdeleo Member
    New York
    It's funny not to long a go a truck with a towing capacity of 14k, payload capacity of 3,500 and around 400hp would have been considered a heavy duty truck.
