Favorite options? I want a snowplow and a winch.
Discussion in 'Cybertruck' started by OConnorStP, Nov 22, 2019.
  1. tomas
    tomas Out of warranty...
    Chicago/Montecito
    Me, I want some snow dogs and a wench.
  2. Feathermerchan
    Feathermerchan Active Member
    Euless, Tx
    My 10,000 lb winch is on a receiver type mount and I can attach it on the front or rear of my F150. I have 4ga wiring to support it run to both ends with Anderson type plugs so it's easy to connect. I leave it off the truck unless I need it. I have used it on both the front and rear. Very handy and it does not permanently take up space.
  3. JRP3
    JRP3 Hyperactive Member
    Central New York
    I've been thinking about the winch setup. Since the truck will have 220VAC a winch setup could draw very low amps and use light gauge wiring compared to 12VDC winches. Hopefully with quick release mounts and plugs front and rear. Plus maybe one at the front of the bed for winching things into the bed.
  4. Feathermerchan
    Euless, Tx
    A 9500lb winch has a ~4kW motor. So 4,00W ÷ 240V = 17A
    It will only draw 4kW at full load.
    I looked and did not find any 240V 10,000 lb winches.
    Maybe use an old drive unit. It would operate at 400V and use even less current.
    Maybe a PTO from the rear drive unit.
  5. JRP3
    Central New York
    • Funny x 2
  6. Feathermerchan
    Euless, Tx
    An old drive unit would be much cheaper and lighter. Maybe Tesla will have an HV (400VDC) winch as an option.
    Still the 12V source has to have a lot of power for the power steering (if the steering is 12V like others today). My F150 has a 250A fuse attached to the battery leading to the power steering.
  7. keeney
    keeney Member
    Minnesota
    Plows need weight carrying capacity on the front axle. They also need a sturdy place on the truck to attach. Unless you baby it, the normal operation of the plow is repeated collisions with piles of snow that can easily outweigh the truck at speeds up to 20 MPH. With the occasional oops where you snag a curb or lip in the pavement, or even a frozen edge of the ground going at that speed. Plows beat up trucks pretty good. If I was buying a used truck, my first thing to check is to look if it has ever had a plow mounted on it. At least the CT, the repeated forward and reversing action won't be chewing up your drive train quite as much (but still some).
  8. ThomasD
    ThomasD Member
    florida
    Wonder what kind of a range hit someone would take with a winch or snowplow on the front of the truck
  9. keeney
    keeney Member
    Minnesota
    The thing is, that little diesel can put out 19 HP at the PTO sustained for hours. In deep snow, that power will be the limiting factor as to how fast you can clear it. 19 HP = ~14 KW. So yes, could make an electric motor that big, but its going to need to tap into the main battery system. Not going to be a 12v accessory. Or add an aux diesel ICE on the snow blower.
  10. Feathermerchan
    Euless, Tx
    Hey Keeney - If you buy your used truck in Tx, I can almost guarantee that it never had a snow plow.
    • Funny x 2
  11. Ocelot
    Ocelot Member
    Canada
    I hope the engineers watch this. Would be nice to have some integrated features. Although was somewhat amusing to see them using an on board compressor, then next frame having to manually pump the 'shade structure'.
  12. Drax
    Drax Member
    United States
    Even funnier now.
  13. Feathermerchan
    Euless, Tx
    Well I'll bet that you cannot find any snow plows in Tx except maybe at some airports mostly to the North. It's just not a wise investment for a once in 50-100 year event. Our house in Houston had plumbing in the attic and it was not insulated. We never had a broken pipe. The service line came out of the ground beside the house and had a drain valve on it so you could drain the system but to my knowledge we never used it.
  14. ThomasD
    ThomasD Member
    florida
    I used to see pickups with plows in Amarillo and Lubbock. North of Amarillo I would see them also
