  • The final cut of the 9th episode of the Tesla Motors Club Podcast, featuring Chad Schwitters, the former president of Plug In America, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Feature request: audible alert that Supercharging is complete, but from car, not on phone
Dear Tesla,
It would sure be nice to have some kind of audible "microwave" type alert to let you know that Supercharging is complete...you know.….just in case you want to take a light nap and want to avoid the cost/price of idle charges due to missing the silent "charging complete" notification on the screen.
Seems like a simple update..... just wondering.
Thanks
Garlan.
While you are waiting for Tesla to make this change, how about turning on notifications on your phone? Or when it says "40 minutes remaining" setting a timer on your phone for 40 minutes?
I've done that, but Tesla's 40 min isn't always 40 min.
However sometimes I pull out my phone and turn up the audio and turn on the Tesla notification sound to get its audible alerts and then after supercharging I go back in on the phone and turn off all of the audible alerts associated only with the Tesla app and then .....blah...blah...blah......
I don't think the request is out of the box.....for goodness sake....we have a fart feature. ( and no....I'm not at all suggesting that the car mimics many humans and "passes gas" (sound) after they get full )
jmaddr
1,149
1,141
Florida
It's a good thought to have it built in for sure, but in the meantime, if you are worried about all those clicks, hide them behind IOS shortcuts or Android Tasker. One touch.
Typical microwaves are around 1000W now. If you take that at 12V you get around 83A for the microwave...I don't see this happening :p
Pretty sure there are 12V inverters higher than that. I think you'd hit the fuse on the 12V plug in the cabin, but not sure about the 12V system overall with the car on. I know on the chevy bolt the max is about 1500W.
The one in the cabin can do 12A continuous or 16A peak... bit shy of 83.
I am aware of that as I mentioned it would trip the fuse of the cabin plug.
I have a 150W inverter on that plug for laptops and such.
Just wondering what the limit for the 12V system is if you tapped it elsewhere, such as at the battery, while the car is running.
There is no current limit ( concerning a circuit breaker - as the model 3 doesn't have fuses ) if you tapped directly to the battery.
Reactions: bijan
I assume there's a limit past which you'll drain the 12V battery in continuous use though? The top up of the 12V battery from high voltage battery must have some limit.
The OEM 12V battery that comes in a Tesla isn't different than a regular ICE car battery.
I know for sure that the 12V can provide the number of CCA it advertises.
I have no intentions of EVER testing it while the battery is inside of my Model 3.
I like a nap, too. And having the car tell me the charging is done would rank higher than awakening with a cricked neck and drool-soaked shirt while paying for idle time at the plug. Yeah, I could use a phone alarm, probably, or bring along the Westclox Big Ben and foam-tape it to the dash. But I'd rather have the car do my bidding, since it does so much else for me.
With the car on the Chevy bolt 12V system will power that inverter just fine, so unclear if model 3 can do it (obviously not from the cabin where the amps are limited). Yes obviously with the car off you'll drain the battery really quickly.
Edit: The limit is going to be the DC-DC conversion between high voltage battery and 12V battery.
Edit2: Nothing official but this indicates 1800W max so it could be possible:
What is the maximum output (in watts) of the DC-DC Converter on the Tesla Model 3? - Quora
