Feature Request: On-Screen Cruise Control
Discussion in 'Model S: Driving Dynamics' started by MrJones390, Feb 8, 2016.
  1. MrJones390
    MrJones390 Space Boat
    Los Angeles
    Someone surely has thought of this and maybe it's illegal, but the idea is to have selectable speeds on the 17" screen once in cruise control.
    Adjusting the cruise lever up and down half or full clicks is not ideal for adjusting speed.
    The screen could have buttons for:
    45
    50
    55
    60
    65
    70
    75
    +1/-1
    +5/-5
    customizable
    customizable
    Would anyone else like this? Is this even possible/legal? Would it only work on AP-enabled cars?
  2. green1
    green1 Active Member
    Calgary, Alberta, Canada
    Far harder to operate, and much less safe than the lever, sounds like an incredibly bad idea to me. (no offence)
  3. .andrew
    .andrew Member
    Gilroy, CA
    My preference is to keep driver controls away from passengers as much as possible.
  4. bob_p
    bob_p Active Member
    At least with the classic speedometers, Tesla's cruise control works pretty well - allowing easy adjustments +/- 1 or +/- 5 using the cruise control stalk.
    From a safety standpoint, changing the speed with hands on the steering wheel is probably better than having the driver divert attention, go to the touchscreen, locate the new speed and then press it on the touchscreen.
    From a user interface standpoint - controlling speed with the cruise control stalk is much more efficient.
    That doesn't mean there shouldn't be more settings available on the touchscreen. One setting that might be useful is to allow the cruise control to do more coasting, allowing the speed to temporarily go a little higher than the set speed - so that less energy is being used when going over hills or overpasses.
  5. cpa
    cpa Active Member
    Central Valley
    With my luck, I would attempt to reduce my speed from 68 to 60; hit a bump in the pavement and accidentally depress the 75MPH button.
