Feature Request: Passenger side key card reader
Discussion in 'Canada' started by noicepls, Jul 16, 2018.
  1. noicepls
    noicepls Member
    Lambton County ON.
    Why is there only the driver-side key card reader in the Model 3? I want access to the inside of the car from both doors; should not have to run over to the driver's side B-pillar to swipe the key card to unlock. When an unthinking/inconsiderate mammoth truck parked so close to my driver side door today, there was no room on that side for anyone to swipe the card, while there was plenty of room on the passenger side. Tesla recommends taking your key card in the wallet/purse in case the phone battery is low or the phone malfunctions, which was the case this time. So the key card did not help because it was unable to get physical proximity to the reader, which is only on the driver side!! The key card reader should be on the driver AND passenger sides! BTW, it is not that hard for an average-sized person to climb over from the passenger side into the driver's seat (I tried and succeeded).
  2. ewoodrick
    ewoodrick Active Member
    Buford, GA
    Regrettably, that's very probably not one of those things that solvable by software and will take extra hardware to implement.
    And in this case, you did had the very rare edge case, phone not available AND blocked door AND Canada.
    The normal solution for this (outside of Canada for now) is to use the summons mode and just back the car out.
    • Disagree x 1
  3. Vawlkus
    Vawlkus Member
    Halifax
    The keycard is intended as an emergency backup key, with the phone as the primary unlock method.
    Personally, I’d rather a fob like my X has, it’s a lot more reliable and less hassle.
  4. pcons
    pcons Member
    Burlington, Ontario, Canada
    If using the phone app, is it possible to open from the passenger side?
  5. ZooSean
    ZooSean ZOO
    Markham, Canada
    Yes
  6. noicepls
    noicepls Member
    Lambton County ON.
    Not when the phone is dead.
  7. noicepls
    noicepls Member
    Lambton County ON.
    Which is why I would like to have a reader on the passenger side too - to be able to use the key card in an emergency.
  8. MP3Mike
    MP3Mike Well-Known Member
    Oregon
  9. pcons
    pcons Member
    Yeah, I figured that would be kind of obvious, unless someone invented a phone with a perpetual motion device inside to power it....
  10. pcons
    pcons Member
    Thanks
