[feature request] Snow driving mode for model 3?
Discussion in 'Model 3: Driving Dynamics' started by cstork, Feb 23, 2021.
  1. cstork
    cstork Supporting Member
    Colorado
    Our model Y has an "Off-road" mode that is very useful for snow. I assume this sends more power to the front axle and allows for a little slip. The model 3 could really benefit from this in Snow. I would think this is just a software update. I'm disappointed that this has not made it to the model 3.
  2. AlanSubie4Life
    AlanSubie4Life Efficiency Obsessed Member
    San Diego
    #2 AlanSubie4Life, Feb 23, 2021
    I didn't know about that Model Y off-road mode. The Model 3 should definitely have that! It is within Tesla's capability, and frankly there isn't much difference in off-road capability between the two models, so this seems like it should not be a feature limited to the Y.
    I drove the 3 in some slop (lots of fresh snow, packed, on ice, just below the freezing point with ample moisture) in the San Diego mountains a few weeks ago, with CrossClimate+, and it was ok, but far from reassuring like driving a Subaru STi (my only reference point). It's annoying how the rear wheels spin first before the traction control catches them (with tons of disconcerting-to-the-uninitiated brake clunking), then shifts power to the front. It would be much better if it just did a 50/50 torque split to start with! It's well known that the Model 3 provides 100% of torque to the rear wheels preferentially on light throttle from a start (tons of videos), and appears to require wheel spin to transfer torque elsewhere.
    I mean, it was fine in the snow, and perfectly adequate to drive, but it kind of sucks to be stepping the rear end out unnecessarily, when you know you just want even torque distribution to start with. I'm fairly sure it's preferred to not lose traction, vs. lose traction and then regain it. In snow, you know it's going to be slippery, so you may as well drive all four wheels rather than just two.
    I assume this is what the Model Y Off-road mode does?
    People have been asking for this for years. Now Tesla is just taunting us.
  3. AlanSubie4Life
    San Diego
    To spare people looking up what Model Y has:
    Model 3 should have this too. Hopefully soon it will be added (I don't know the implications for EPA rating and whether it has to be counted/averaged in - if so we'll never get it). I have heard that Model Y drivers say it is helpful in the snow but more feedback from people who have experience with it would be nice.
  4. Snow Drift
    Snow Drift Pirelli P Zero Winter
    Long Island
    @AlanSubie4Life If you have a M3P, you can use Track Mode to change the F/R bias to your desired amount. 50:50, 30:70, 41:59, etc.
    Personally, I never had an issue with the M3 or MY RWD bias and I also have a history with 2018 STI, '05-08-11 WRXs and '15-19 Crosstreks.
    • Informative x 2
  5. AlanSubie4Life
    San Diego
    Darn, definitely should have thought of that and given it a try so I could compare. Going to be a few years before I can try again, probably.
    I can only speak from my single experience. As I said, it was workable, I wouldn't call it an "issue" exactly, but nothing like driving a vehicle with a partial torque split. The conditions were optimally slippery, though, of course.
  6. Rhytid
    Rhytid Member
    Maryland
    I have noticed that the Model 3 feels a little squirrely in the snow or ice compared to other AWD cars I have had in the past.
    I have read that this might be due to Model 3 being mostly a rear drive when under light throttle or when starting gently from stop and the front motor is used when under heavy throttle or when car senses slip in the rear wheels.
    So the car may be in complete control but it just doesn’t “feel” like it for that split second.
    My wife’s Model Y has an off road assist mode and this made me think (dangerous, I know).
    What if I turned on Track Mode and set it at pure 50/50 split with Stability control turned to Max? Would that feel like Audi AWD?
    Let me know if this sounds feasible or if it is complete whack.
    Thanks for looking.
  7. GAGT
    GAGT Member
    Roc, NY
    Not sure what the problem is? I have my bias set to 10/90 stab -10. She drifts the corners like a pro. *shrug
  8. GtiMart
    GtiMart Member
    Quebec City, Canada
    Yes! Model 3 needs snow mode. But not to restrict it more... It limits power like crazy already. A snow mode would not reduce power as much, allowing some twisting of the car angle, and would indeed put power to the front earlier. I don't have a P so track mode isn't available. In snow, the car feels so restricted it's almost crazy.
    My previous WRX had an optional traction mode that would reduce the assists a bit, drastically helping in snow.
  9. MagnusMako
    MagnusMako Member
    Austin, TX
    I'm curious how much difference there is between the off-road mode in the Y and the slip-start in the 3. Does the Y also have a slip-start mode? I wonder how that works in conjunction with the off-road mode as well.
  10. vogz
    vogz Member
    Batavia, IL
    What you are experiencing is more likely due to the tires than the drive system. My previously car was an Audi S4, and I run winter tires on my cars in the winter months. Overall, I would say the Model 3 is actually better and more predictable in the snow than the S4 was. They are both fantastic, but the Tesla seems to find the limit of traction more quickly and do a better job of holding it there.
  11. Rhytid
    Rhytid Member
    Maryland
    Sorry I didn’t put it in my post. I DO have winter tires on the model 3.
    Interesting that you compare to Audi S4 as I had the S4 as well (ran with winter tires). I feel the opposite of you, though. I feel like Audi felt better “planted” in slippery conditions.
  12. vogz
    vogz Member
    Batavia, IL
    That is interesting. I wonder what's going on. What winter tires do you run and how worn are they? I run 235 Sottozero 3 performance winters on 18s and they only have about 5k miles on them.
  13. Rhytid
    Rhytid Member
    Maryland
    I have the Sottozeros as well but in 19 inch. I probably have around 10k miles on them. But still plenty of tread left. Maybe my ass is too sensitive to squirreliness.
