doctorwho
I keep thinking that I'd really like to see reverse cycle air conditioning. It wouldn't be too difficult to implement although it would be a little more expensive. It would react faster than resistive heating and uses much less energy so heating would have much less impact on range. The problem with reverse cycle is that they lose efficiency at low temperatures as they have to transfer heat from the outside air to inside the car but new hot water heat pump systems like those made by Sanden use CO2 as a refrigerant (ironically) can operate effectively well below zero degrees C. They do operate at higher refrigerant pressures so it would require some minor re-engineering.
