Figured Ash Wood Care
Discussion in 'Model S: Interior & Exterior' started by DoubleACL, May 20, 2017.
  1. DoubleACL
    DoubleACL Member
    Orlando, FL
    Aside from having tinted windows to reduce UV damage, is there anything that should be done to care for the trim, such as with wood finish products used for wood furniture?
  2. ZERO260
    ZERO260 Member
    Waldorf MD
    I have the same trim. Easy to maintain. Nice coat of lacquer. Microfiber towel to wipe dust or finger prints is all that's required.
  3. JasJ
    JasJ Supporting Member
    Houston, TX
    What lacquer do you use?
  4. ZERO260
    ZERO260 Member
    Waldorf MD
    The trim has factory clear coat. I do not apply lacquer.
  5. timvracer
    timvracer Member
    Los Gatos, CA
    I had my entire interior ceramic coated - it is now super hydraphobic, even the carpet. Spill on it, and you just pour it off.. does not soak into the fibers. same with dash, alcantara, leather seats -- even did the windows, which makes them super easy to clean!
  6. Texas
    Texas Supporting Member
    Houston, Texas
    I have obeche wood matte finish. It didn't have the visual quality of real wood, so I applied 3 or 4 light coats of natural (soft) paste wax with a high beeswax content. I polished each coat with a low speed lamb's wool buffer. At the end of this process the obeche acquired the subtle luster of fine furniture. It still looks great after a year.
