tvad
Jeebus, do you grind on all your daily decisions like this?
It’s just a car.
Man up and make a decision.
It’s just a car.
Eating the depreciation on a one-month-old car to upgrade to one that's a little bit quicker off the line, is fine if you are loaded and don't know what else to do with your money.
I wouldn't call 30% faster "a little bit quicker".
I accelerate hard whenever the opportunity presents. The Roadster's acceleration (around 4 seconds to 60) was a real rush. But even my LR RWD is so quick it leaves all the other cars behind. And now that my electricity is free, there's no reason to conserve energy. By 2:00 p.m. my solar panels shut down because the Powerwalls are full and there's nowhere for the energy to go except when the A/C comes on.
But you know what? I don't miss the slightly quicker acceleration of the Roadster. The difference between 4 and 5.1 (?) is hardly noticeable. Here's something else curious: When the Model S appeared in trim lines that were quicker than my Roadster I felt bad that mine was no longer the quickest car. The Roadster was supposed to be a quick car, but then was no longer the quickest. Now that I've got a car that's not supposed to be the quickest, I feel no envy at all towards people who have the quicker trim lines. It's much more important to me that my car is comfortable, has a great sound system, has EAP, and runs on free, zero-carbon solar energy.
I also appreciate the better handling package as so-cal roads are pretty nice.
30% quicker?
The AWD is 4.0 (when measured the same way as the P).
30% quicker would mean the P does 2.8... which it certainly doesn't.
20% is a lot nearer correct.
If you want extra math you then have to consider what % of your driving is 0-60 (because north of 60 the difference almost entirely vanishes).
For some folks that's like 99% of their driving, so even 20% might make a huge day to day difference.
For me it's maybe I dunno 5% of my driving? The other 95% is highway driving at speeds where there's little to no difference between the cars, so 20% quicker 5% of the time is...not much...
nobody's really demonstrated any appreciable difference between that and stock from a performance handling sense
measured number of ~3.0 for P3D
I lent my buddy my vbox, and he has an AWD, non-P, and his 1ft rollout speed was sub 4 seconds actually. i think 3.89ish. couple of feet downward slope, so not much.30% quicker?
i had 3.15 (P3D-) without removing anything from the car (tuxmats, etc), with 1Ft rollout. But i agree, i don't think you can get sub 3, unless maybe you remove the back seats, tires, and battery.Source? I have a P3D+ and with everything removed from the car and my 155 pounds in it, it's about 3.17, without rollout. 3 seconds is absolutely unattainable without removing weight or going downhill. No matter how light your aftermarket wheels (unless you make them non-stock diameter). 3.1 is about as good as it gets and you have to be light. And probably doing it while it is super hot at high elevation will net you some tiny gains as well.
If you take user measured numbers of 4.0
Motortrend said:This 4,062-pound Model 3 Long Range Dual Motor hit 60 mph in just 4.0 seconds and passed the quarter-mile finish line in 12.5 seconds at 113.1 mph
That's some weird math with regards to what speed you're driving most of the time (which is apparently 100 mph )
. What you should actually look at is where most of your acceleration happens
, and even if you're driving at 100 mph on average almost all of the acceleration is happening in a range where the P3D is significantly faster.
If you live near a city or have to deal with any kind of traffic (or drive near the actual speed limit) then acceleration above 70 mph has pretty much no relevance to you. If you live in the sticks, then acceleration has little value beyond entertainment.
[/QUOTE]If he's considering a P3D- the handling is exactly the same as the car he has now (except arguably the benefits of track mode if you choose to use it on public roads)
If he's looking at the P3D+ it's all of 0.39 inches lower- but nobody's really demonstrated any appreciable difference between that and stock from a performance handling sense... (just from a "much more likely to kill your wheels on potholes" sense)
This suggests that after 60 the cars are virtually a dead heat (and there's more data showing that as well- the P being very very very slightly faster after 60- versus below 60 where it's 20%+ faster). ...
That's at highway speed.
Where the 2 cars are virtually identical.
Have a look here and you can see the difference in HP is about 100 (450 vs 350) at 60 mph (7k rpm).
I can tell you the only time I need acceleration above 70 mph is when I'm trying to pass someone who is already speeding (this should apply to most states). Most of the time when I'm passing people I'm on a highway with a speed limit between 50 and 65 mph and the people I'm passing are going at or under the speed limit. There are no roads in NY state that I'm aware of with a speed limit above 65 mph. Maybe it's different in NC?
It comes with the PS4s which are far better than the stock 18s. I test drove both...stock the Performance pack makes a big difference on grip.
