Finally my 18” snow wheels
patnshan
185
149
Milwaukee, WI USA
Finally received my new winter wheels for my Model Y LR AWD. Was so happy to replace the absolutely terrible in winter Goodyear pseudo all season tires. I’ll still use them for summer until they wear out. I installed these myself at home using my new low profile jack, which worked perfectly with the amazon jack pads I bought.
These are 18” MSW Model 48 with 245/55R18 Blizzak LM-32 tires. These have factory TPMS sensors. They calibrated right up. There is no option for configuring 18” wheels via the Tesla screen. I left them alone (summer wheels are 20” induction) as the overall wheel and tire diameter is only 0.6” taller than stock configuration so I doubt it matters much. The ride is unbelievably smoother than the inductions due to more rubber. Haven’t tried them out in deep snow or ice yet, but they were solid in light but slippery snow. Excuse the salty car, The Demon needs a wash
Wanted to post in case anyone was considering downsizing the rims in favor up upsizing they tires for winter.
mark95476
1,484
847
Bay Area CA
Good choice with the Blizzaks on smaller rims.
Reactions: patnshan
daapilot
New Member
Jan 25, 2021
3
2
connecticut
I also changed to the 18" blizzak snow tires yesterday, coming from 20"induction wheels. After the change, I have noticed a noise or creak when decelerating at low speeds to stop. I don't know if I need to change any settings? Did this happen to you?
Reactions: patnshan
patnshan
185
149
Milwaukee, WI USA
No, not at all. Hmm. Did you make sure the centering rings are installed if needed for your wheels? Mine had them. Otherwise, not sure as mine aren’t behaving poorly at all.
daapilot
New Member
Jan 25, 2021
3
2
connecticut
I also ordered my winter setup from tirerack and had centering rings installed. I do not have any vibration issues. My noise sounds more like the regenerative braking is engaging abnormally. The noise is definitely something new since the install. It only happens at very low speed to stop.
patnshan
185
149
Milwaukee, WI USA
Yeah, that’s odd. I definitely don’t have any issues like you describe. I hope you are able to figure it out.
jcanoe
2,581
2,555
Maryland
Per the 2020 Model Y Owner's Manual, page 69:
Note: Installing winter tires with aggressive compound and tread design may result in temporarily-reduced regenerative braking power. However, your vehicle is designed to continuously re-calibrate itself, and after changing tires it will increasingly restore regenerative braking power after some moderate-torque straight-line accelerations. For most drivers this occurs after a short period of normal driving, but drivers who normally accelerate lightly may need to use slightly harder accelerations while the re-calibration is in progress.
Reactions: Tedkidd
daapilot
New Member
Jan 25, 2021
3
2
connecticut
thank you jcanoe and patnshan. I remember reading that statement a while ago, but completely forgot about it after my install a few days ago. An update, during driving today, it seems like things have recalibrated and pretty much the noise is gone.
Reactions: patnshan
Daks
131
91
Anchorage, AK USA
So you are aware on the MYP the rear tire is 28.6" tall from the factory, so yeah, likely no issues at all.
Reactions: patnshan
