Firmware 1.21.0
Discussion in 'Tesla Energy' started by Icepicknz, Jul 26, 2018.
  1. Icepicknz
    Icepicknz Member
    Auckland new zealand
    Seems i was updated yesterday and all my scripts have stopped working to charge / consume...
    {"code":500,"error":"RealMode must be either self_consumption or backup","message":"Unable to set operational mode"}Barrys-MacBook-Pro:~ barrymurphy$ curl -sk --header "Authorization: Bearer TjrnGcgW9qE4NUE69l6ed6GOz01N7nbAoB_CEZbLbyglSpqUr2VxcTd-iqlaby2YzwJw7TZ4EDkCTRZpzfh9zA==" -X POST -d '{"mode":"self_consumption","backup_reserve_percent":15}' http://192.168.33.9:81/api/operation
  2. Endoplasmic
    Endoplasmic Member
    SJ, CA
    You may want to edit your post to remove your oauth key :D
  3. Icepicknz
    Icepicknz Member
    nah its ok, changes each time i re-auth plus have to be local to my lan to use it
  4. Sylvia Else
    Sylvia Else Member
    Sydney
    At a guess, they've introduced a new field, which is probably called "real_mode". You could try including that and setting it to "self_consumption".
  5. Sylvia Else
    Sylvia Else Member
    Sydney
    Rather than add a field, the've changed the existing field name from "mode" to "real_mode",
