Got my upgrade to 4.3 a couple of days ago. But ever since the update I can not turn the air conditioning off anymore. Changing the setting from AC On to AC Off isn't doing anything. Today was a warm day (>30C) and while the sunroof was open I didn't want the AC running. But despite turning it off it continued to blow called air. Anyone else noticed that?
try rebooting, both center console and instrument cluster, although it's probably only the former that requires it. i'll bet it clears up your issue.
- - - Updated - - -
The headlights are HID (Xenon) when you get the tech package. You can hear the arc strike when you flash the bulbs. And there is about a 0.5 second delay for the ballasts to build up some voltage.
i don't think that's exactly right. i think what you hear is the reflector sliding back and forth. i believe that's how they make high and low beams in these systems, by adjusting the reflector, and that actually the lamp is a constant brightness. could be mistaken...
EDIT: unless you mean from an off position, firing up the lamps, yes, then that would be an arc striking situation. sorry, think i misunderstood.
