Yeah, after waiting months for the previous update, was surprised to see the install alarm pop up while out running errands this morning.They must be confident about this update. Fast rollout.
It seems auto mode for HVAC in 4.3 is now properly tuned for warming/venting car in the cold. It's 0C (32F) here and, so far, flawless. Huge difference.
Just installed 4.3. Canadian owners rejoice! The rated range line in the energy app is now correctly displayed.
Will test the updated range in cold weather this pm.
Hi Patp,
How long did the update take ?
Good. Hopefully this fixed the temperature sensor. I always felt like the AC was on when heat should be blowing out. I'd have to set my temp to high to feel warm air coming out. But clearly it was obvious why it was like that when I check the remote app. The remote app shows 84 degrees inside the car when it's 30 degrees outside and I have the inside temp set to 76. Inside temp was probably closer to 68 and the damn AC is on instead of heat. Car thinks its 84 degrees in there LOL no way
Don't know exactly. About 30-40 min.
- - - Updated - - -
Great , thats what i thought.. it says '2 hours' but its usually much shorter... so i will run the update now, while at work
I think it's generally a good idea to do the update at home. That way the car is sitting there safe and you are already home in case something happens with the update.
Less than 15 minutes for me.
I can't quote my source, but let's say the sensor isn't placed at the ideal place... But Tesla has been working hard on improving the software on that issue. It's almost too hot in the car now
When charging is delayed and you're plugged-in to a Chargepoint station, does the station register as being used or available?
Interesting. I hit the "install" button shortly after 1 pm. The car had been recently driven but the pack wasn't fully warmed. I didn't plug it in. At 1:19 pm I used the App to check the range - said 352 km.
I just checked the App again, at 2:56 pm. It had been out in windy -7C conditions for a couple of hours. It now shows 356 km.
Never seen the number go UP while unplugged before...
