Strange Issue with braking system
On Friday I experienced what appears to be a known glitch with the car. At a stop light, the car indicated that it was off by showing the picture of the car and the charging status where the speedometer should be when driving. Seconds after the 17 inch display went out and re-initialized itself. The car was in fact still drivable but when the display came back up there were four errors total, three on the 17 inch display and one in the instrument cluster. On the display: "Traction Control disabled", "Stability control disabled", and "ABS needs service". On the instrument cluster: "Regen disabled". At the time I was only about two miles from my job. I continued driving to work and when there I forced the car to shut down via the controls page, everything came back up as normal.
After speaking to Tesla they said they had seen the issue before and were working a permanent fix. They provided me an update over the air v4.5(1.33.59) that apparently minimizes the occurrence but is not the final fix. This is the first time I've seen the issue and it appears its only a glitch that can be solved by turning the car off and back on. Not a huge issue to me and was pleased with Tesla's quick responsiveness to the matter.
