Firmware 4.5
ShortArc
97
13
Massachusetts
.61 brought about a few new bugs for me:
Radio does not stay muted on re-entering the car.
From time to time when actuating the door hadles with the keyfob the fog lights will come on.
NigelM
Recovering Member
Apr 3, 2011
13,386
555
Northern Virginia
It has always been the case (for me a least) that the radio returned to previous level on re-entering the car. Also IIRC the lights come on briefly when the handles present (although that might be because my car is in a garage).
ShortArc
97
13
Massachusetts
Interesting...the Radio (any audio source) coming on automatically when entering the car (not every time BTW), when put on mute on exiting, is definitely new for me with .61.
I can not say I remember the fog lights ever coming on unlocking the car but I can not be certain.
brianman
Burrito Founder
Nov 10, 2011
17,515
2,980
Are you referring to the auto-mute (quiet) feature or did you physically turn the sound off?
I pause Slacker every time I leave the vehicle. It reliably stays paused when I do that no matter how many times I "tease" Tess (walk by her in the garage with the fob but don't let her out to run).
gg_got_a_tesla
Model S: VIN 65513, Model 3: VIN 1913
Jan 29, 2010
6,533
769
Redwood Shores, CA
Yes, Slacker stays paused. However, I've noticed previously-muted FM radio come to life when I come back.
ShortArc
97
13
Massachusetts
I was referring to "pause" ie. "mute". I know for sure the Radio does not stay "paused" all the time but now that you guys mention Slacker does...I will have to recheck. Thought I had the same issues there but maybe not...
ZBB
Emperor
Feb 27, 2013
1,543
267
Scottsdale
I returned from vacation yesterday and had the .61 update waiting for me. I installed it yesterday afternoon -- the first one I've been able to do (the car was previously updated from .38 to .48 by the service center). It looked like it was successful, and the about screen shows its on .61.
But the car put up a message the next time I got in the car (an hour or so later) saying that the update had failed and it would need try to install again, and would let me know when it was avail. But nothing this morning, and all functions appear to be working correctly.
Anyone else had this? I may just wait a few days unless I notice any other issues, and then call Ownership...
PhilBa
1,382
68
Seattle
a couple of issues I noticed after the .61 update.
  • putting car into park to extend handles stopped working. worked before the update (and yes, I rebooted the console).
  • horn stopped working from the wheel pad. still works via the app.
Todd Burch
Voltage makes me tingle.
Nov 3, 2009
7,801
28,498
Smithfield, VA
I have .61 and both of these work fine. Contact Tesla, that's not a widespread bug.
mknox
10,103
1,866
Toronto, ON
I had the "handle stop extending issue" after the update prior to .61, but they eventually started working again. Give it a couple of days (seriously).
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
So, in summary, .61 is a bug-ridden mess and should be avoided?
No, it's mostly working just fine. I have two minor issues that have appeared since its installation:
  • Homelink menu popping down causes rear view camera image to disappear if you have it displayed in the top panel. Slightly annoying, 100% repeatable, but fairly easily worked around (i.e. force the menu back up again)
  • Twice now my rear left door handle has failed to retract properly
bob_p
3,594
2,748
Since there haven't been any reports on updates later than .61, it appears that may be the final and "stable" 4.5 release.
I had a small problem after installation with passenger door handles extruding while the driver side handles were retracted. The local SC tracked that down to the firmware update not being complete for all subsystems - and after they forced another .61 update to the entire car, the problem has gone away.
So if you're having problems, I suggest you first try rebooting the dashboard and central console - and if that doesn't fix the problem, have the local SC check out the issue - and see if they need to re-apply the .61 update.
