Well I hope they come up with a next release soon as I discovered a major issue with the charging infrastructure here in Estonia. The ABB chargers will provide 3x32A on the Type-II connector, but after 5 minutes of usage the charger will check the actual amperage. If the usage is below 16A per phase it will swap over to 3x15A relay however that swap will cause a short loss of power on the feed and the Model S will stop charging with an error message of lost wall power. Now if the Model S were pulling with twin chargers (i.e. 3x26A right now) then this is not an issue as the system sees >16A usage. If the single charger were drawing the full 3x16A as designed it would also not be an issue, but as we're limited to 3x13A the swap occurs and I can charge max 5 minutes, then need to disconnect cable, reconnect and restart charging (also registering a new charge session and hence paying more money). I've notified Tesla about this and they are talking with ABB, but they didn't have the limitation removal FW available or they would have pushed me the new one as an experimental version. So I sure hope they either will communicate at start of charging that they only need 3x13A (in which case the ABB charger immediately gives only 3x15A relay) or they remove the limiter as otherwise for single chargers the ABB charging stations deployed here (and possibly elsewhere) are useless or need a new firmware to avoid this switchover that is needed to dual charge Type-II AC and CHAdeMO DC at the same time to two cars.
