Firmware 5.8
B.TSLA
36
0
B.DOT
Software Update - Could this be 5.9????
Going through the process right now. I wonder what new features this has in store.
This update screen didn't have any specifics on the firmware revision or features....
B.TSLA
36
0
B.DOT
Thanks for the heads up. I wondered why it didn't have any details about the update as we've seen in previous updates.
Any noticeable / noteworthy updates to 5.8 that you've noticed??
Todd Burch
Voltage makes me tingle.
Nov 3, 2009
7,801
28,498
Smithfield, VA
I can confirm that .30 does *not* fix the ambient light buzzing.
(BTW, is this a problem on newer cars?) If you're not familiar with it, if your headlights are on and your touchscreen brightness is set to 86% and below (that's the exact threshold on my car--starting when going from 87% to 86%) you can hear a faint buzzing noise. Turning up the brightness, turning off the ambient lights, or turning off the headlights will stop the noise.
Otherwise, I had zero issues with the install itself or anything after it. Did not need to reboot at all.
ddenboer
MODEL X #1770
Dec 21, 2011
318
6
Austin, TX
Every loaner car I have had has worked properly WRT ambient lights. Mine does not, but Tesla denies the problem repeatedly during my service visits. It stinks not being able to use that feature.
Chris TX
1,531
186
Dallas, TX
Hey guys, I just found out from the SM that rev .30 ups the amps on the USB ports, too. 2.1A for the driver's side and 1A for the passenger side.
No more need to have the higher amp charger stuck in my 12V socket now! W000T!
Also, the .30 update discovered that I have a malfunctioning (mechanical) passenger rear door exterior handle actuator. C'est la vie.
And yeah, I would LOVE to get a line-by-line breakdown on what these updates fix. Of course, if this was normal software/hardware OEMs, you'd get a large list of good and bad. Maybe Tesla only wants us to see the new whizzbang enhancements.
jomo25
2,105
224
Scottsdale, AZ
Except that even the good thing you mentioned (2.1A USB output) isn't mentioned.
LuckyLuke
Model S P90DL
Dec 14, 2011
2,270
542
Eindhoven, The Netherlands
1.49.30 now rolling out in Europe as well, took under 30 minutes to install (from .29)
