yobigd20
Low ride height has NOT been restored. It's different now sort of but still broken in this latest update - 1.49.30. If anything, it seems even more broken now than before. Let me explain.
thoroughly tested this on my way to work this morning.
First thing to note that when parked and set to low, when you change to drive it auto raises back to standard. Ok. Trying to change to low at very slow speeds < 10 mph will get rejected.
However, above 10mph you can manually set to low and it *seems* to stick. Even stays low at highway speeds. For a while. I'll get back to this.
It also still auto-lowers at 97mph too (really? you guys haven't fixed that yet???) and sticks until you fall back below 65 mph at which point it auto returns to standard height again.
So this brings me back to my earlier point. If you set low manually it stays low. If you speed up to 75 mph then slow to 50mph it stays low. BUT if you set low manually and then go above 97mph then drop below 62 it will auto raise again and then it will NOT let you manually set to low anymore. I had to come to a complete stop and park to reset again so that I could start driving and manually set to low for it to stick.
Now at 75mph changing to standard works but then manually going back to low is rejected.
Finally I did a full system reboot and now none of that manual lowering is working anymore.
This is really starting to piss me off.
At first I thought the takeaway from this is to AVOID going over 97mph. But now I am thinking that the UI is just more susceptible to being broken and showing the wrong ride height. Obviously as I'm driving I can't really tell if those ride heights were actually working at all anyway.
My conclusion on this is that low suspension remains disabled. If anything, the UI seems more broken.
