ModelSFL
How was the experience upgrading from the side of the road? [emoji1]And on the other side of the coin: I LOVE THE NEW UI (ic anyway, I don't like the flat, bottom row of the 17")
Update: SC called me back. Said it looks like a symptom of a hardware related problem. Probably need to take the car in for service to get it to update properly. I may have an older version of some part that has to be swapped out.
Just balancing the negativity by the loud few:
I LOVE the new UI, I LOVE the car showing which sensors it sees and where in the lane it is. I LOVE almost everything about the new IC.
Did this person do something wrong in this case with autopilot? I know it is normally meant for highway, but what do you think happened here since there are double yellow lines?
It looks like the sun blinded the camera as he came up over a hill and the car set off the "take over I can figure this out" alarm.Did this person do something wrong in this case with autopilot? I know it is normally meant for highway, but what do you think happened here since there are double yellow lines?
Wow indeed... scary. And this is within hours of v7 being rolled out. I'm guessing we'll see a lot more of this over the next few days and weeks. Let's hope they all end as harmlessly as this one.Did this person do something wrong in this case with autopilot? I know it is normally meant for highway, but what do you think happened here since there are double yellow lines?
"How much range and battery do I have lef... oh, look! Pretty lights!" Seriously...?
4) It’s easy for the car to get confused, and it’s not gentle about its decisions. After entering the 520, facing away from the sun at the hour, the car couldn’t decide what to do about a slightly wider than normal lane. It literally shot the steering back and forth as it hunted from edge to edge, like a teenage driver losing control. The system also didn’t want to relinquish control to me, as I thought overriding it with manual pressure on the wheel would cancel it’s erratic behavior, instead it was a wrestling match until I hit the brakes on the freeway, further destabilizing my mass. Needless to say, the other cars on the highway were giving me a wide berth by this point.
Update again: My drive unit has a part that is incompatible with AP. Taking it in tomorrow to get replaced.
TL;DR: If your installation fails, call your local SC. You may need to have your car serviced.
Yeah, because the forum is filled with those negative people and their posts...
Seriously: good for you. I'm sure this will work great for many people. I am well aware that I am in a minority here.
Are you criticizing me over this? Really? I didn't design this. I would rather have the battery front and center as well but it's still there. I can think of the last time on a normal day (not traveling) I panicked because the battery gauge wasn't directly below the center of the screen. Everyone is different though. It you look a few inches over to the left and down it is there. They don't take it completely away.
WTF? Did your car work with TACC? What does steering have to do with the drive unit? I could see if somehow it wasn't compatible with cruise control as that makes the drive unit go, but if it's going on TACC, that doesn't make sense. I bet it's a bug.
I am guessing that 2% of the people will get excited about something that Tesla said might be a problem ("Keep your hands on the wheel", etc.) and will post something like "Tesla Tried to Kill Me!!!" Really??
NO kidding.
#1. Bad idea to take his hands so far away from the wheel on a challenging, curvy 2-lane road with oncoming traffic right next to him, which Tesla explicitly stated autopilot was not intended to be used for. If you want to test limits on a road like that, your hands had better be right next to the wheel.
#2. Even worse idea to do it while filming himself with a smartphone.
(wk: removed poorly titled video)
