Firmware 7.1
Discussion in 'Model S' started by NOLA_Mike, Jan 9, 2016.
  1. apacheguy
    apacheguy S Sig #255
    So Cal
    I can't believe they still haven't fixed this.
  2. Boourns
    Boourns Active Member
    Dallas
    Hmm I see. Somehow have missed that thread. Thanks.
  3. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    I'm still on 7. 1 with no plans to upgrade unless forced to.
  4. HankLloydRight
    Connecticut
    That's true for about 100 demonstrable things.
  5. Pilot_51
    Pilot_51 Member
    Metro Detroit, MI
    I had that problem from January 2015 until August this year. After several attempts by service and owner support to resolve it, owner support finally found that my car was somehow marked as not delivered. Once that was fixed, I started receiving automatic OTA updates again.
    • Helpful x 2
    • Informative x 2
  6. davidc18
    davidc18 Active Member
    Ft. Lauderdale
    Staying on 7.1
  7. GlmnAlyAirCar
    GlmnAlyAirCar Active Member
    Sanatoga PA
    Good for you.
  8. apacheguy
    So Cal
    True, but in the case of limited ac recirc we are talking about a feature that was present on the car at delivery and has been significantly degraded.
  9. Pilot_51
    Pilot_51 Member
    Metro Detroit, MI
    I can't say I've noticed the recirculation issue, but I have noticed that the max temp was recently dropped from 90F to 82F. I was turning it on through the app, bumped it up to 90F to get it warmed up faster, and it snapped down to 82F. Confirmed that the car now designates 82F as HI. It's sometimes annoying that the people who make my car function mostly only know California weather.
  10. jgs
    jgs Active Member
    Ann Arbor, Michigan
    I've noticed that too, but at the same time when I do kick the temp to HI I've noticed the car has reported interior temps as great as 92F. Are you using HI to run the heat aggressively (my use) or because you want to minimize use of cooling?
  11. Pilot_51
    Pilot_51 Member
    Metro Detroit, MI
    Mostly because I want it comfortably warm in the few minutes it would take me to get to the car. I tend to not turn it on until I'm starting on my way to the car. Plus, I've had at least one time recently where even HI (82F) wasn't enough to get me feeling warm enough in a 20 minute drive. On the other hand, I also didn't think to switch vents to manual, and auto tends to do anything except upper-body vents.
  12. jgs
    jgs Active Member
    Ann Arbor, Michigan
    Oh right, you're just around the corner, I should've realized you were using it for quick heating. Anyway, like I said you might check whether HI is actually treating 82F as the set point where it cuts the resistive elements out, because my limited experience is that it's not. My guess (that I haven't tried to verify) was that the scale goes ...79F, 80F, 81F, full-blast (which sometimes gets rendered by UI elements as 82F), and that the only real change vs. earlier versions was the decision that we don't really need settable increments degree-by-degree all the way through the eighties -- that it's basically 70s and then "all the heat". Which, if true, WFM.
    (I use HI a little differently than you do -- I find regular preheating good enough most of the time, and just use HI to heat soak the car for road trips.)
  13. GeorgeCM
    GeorgeCM Member
    Europe
    Anybody has a 7.1 software image ? Or a rooted car running 7.1 ? I need it to update a model s ver 6.2 which has a stupid bug in Chademo protocol. I can help with instructions to grab it from the car if necessary :) Please pm!
  14. davidc18
    Ft. Lauderdale
    I am still on 7.1
    send a PM
  15. Newportcgt
    Newportcgt New Member
    Newport Beach
    I just gotmy Model S P100DL and love the car. Funny how the simple homelink feature and others like it make the car feel so much better than any other car I have.
  16. profilehair01
    profilehair01 New Member
    ludhiana
    The whole infoirmation yopu shared via this thread is really beneficial and thanks for posting it.
  17. Lex
    Lex Member
    Toronto, Canada
    Hi mods, can someone please unsticky this thread... can't think of any reason to support it staying stickied (and frankly I would say don't stop with this one ;) thx
  18. bmah
    bmah Moderator, Model S/X, California Forums
    Lafayette, CA, USA
    Good point, done.
    Bruce.
  19. Barry
    Barry Active Member
    Colorado
    And I just clicked Unwatch thread :)
  20. NikeWings
    NikeWings Active Member
    Thanks for the memories 7.1....man we learned a ton here.....had some entertainment too! :rolleyes:
