No worries. Gewoon de instructies op de schermen in de auto volgen, dan gaat er niets mis.Ik heb mijn MS pas een week en kreeg gister de melding op mn Iphone dat de SW update niet goed is verlopen. Hoe werkt dit: snachts ? moet ie daarvoor aan de lader hangen ? wat als de Wifi niet werkt, pakt hij dan 4G?
I'm 5'5" and I just tried adjusting my seat in every possible way and could not find an uncomfortable seat belt position.For instance, while the seat distance and steering wheel extension are better than some other makes, the fixed seat belt height is troublesome for people like my 5'6" mother.
I assume you have a way to bypass this already?It's not, unfortunately. Tesla's updates are currently still push only, where Tesla decides who gets what.
But since we're leaking 8.0 info, I'll express my dislike for it with one image:
Nee. (Waarom het forum vervuilen met dergelijke berichten, als je binnen het uur kunt weten dat het gewoon een recente 7.1 update is?)
Neem me niet kwalijk, ik heb de auto niet bij me en was erg enthousiast.
Zal voortaan goed opletten wat ik opschrijf.
If you have driven on 8.0, can you comment on upgrades to Nav? Supercharger accessibility and waypoints???I have driven on 8.0 extensively, but I also have it on the bench for testing things you don't want to test in a working car. The photos I posted are from the bench.
probably what happens once you get off the interstate... Basically anything with intersections it's not going to engage? I was wondering when they would do this...It's not, unfortunately. Tesla's updates are currently still push only, where Tesla decides who gets what.
Yea that was my 2nd thought... Hopefully I'm wrong and you're right... either way annoying as heck but understandable given all the crashes from people thinking their car is Johnny Cab from Total Recall.I don't think so, it says "for the rest of this drive" which sounds like the announced penalty box you get put in after ignoring three audible warnings in an hour.
The interface has been redone a little bit.
You can set a "favorite" by pressing anywhere on the map. It will allow you to name it whatever you like, but it pre-fills with the closest street address.
To locate a charger, you click the lightning bolt icon on the lower right and it brings up all the charger pins on the map. The dialog on the left shows a list starting with Tesla then destination chargers you can pick from, or you can click the pin on the map.
You can do a quick press and swipe down on the menu button to navigate home.
I don't see any real-time supercharger data, nor any files being downloaded that would indicate this is possible.
So basically some improvements in terms of usability, but no new functionality whatsoever (such as e.g. entering waypoints). Correct?
I think someone makes a little contraption than can move it down. I don't remember who sells it though.That's good to know. I am 5'3" and am doing a test drive Friday. One of the things I am going to pay close attention to is the seatbelt shoulder location. My Volt doesn't have a shoulder belt height adjustment either and I have to raise my seat position quite a bit to avoid seatbelt neck chafe.
