Firmware 8.1 - Classics
reddy
878
1,084
Amarillo, TX
2017.40 seemed to trash my Homelink. It become unreliable on autoclose, and you couldn't manually toggle the Homelink function if autoclose failed.
Supposedly 2017.42 fixes that, and adds better XM categorization.
dgpcolorado
high altitude member
Apr 25, 2015
2,476
3,281
The Western Slope, Colorado
I had the Homelink issue on 2017.40.1 although it was intermittent. Homelink seems fine on 2017.42 so far.
Fiver
1,853
1,543
Utah
This is more of a general 8.1 question, but since I have a classic I'm posting here. Does anyone know if there is some sort of hardware limitation on the power seats and steering wheel that prevents them from all moving simultaneously? My Tesla was in service a few days ago and I got a Infinity loaner for the day. (Bleh). One nice thing about it was the easy entry/exit mode in the car moved the seats and wheel at the same time so the adjustment was quick.
When I got my car back from service it had the latest firmware that added Tesla's version of easy entry/exit, and I found it annoying that the movements all happen one at a time: Move seat back, then lift seat up, then tilt seatback forward, THEN move steering wheel in, then finally move steering wheel up out of the way. Is it a software thing for the movements or is the hardware just not capable of all moving at the same time? Any ideas?
If they just can't all move at once, it would at least be nice if the steering wheel moved first (vs last) as that's usually the biggest thing in the way making in/out slightly more difficult.
Reactions: dgpcolorado
Fiver
1,853
1,543
Utah
For what it's worth, I got 2017.46 3387a54 last night. No new forward facing features to the end user for us classic owners.
SmartElectric
2,380
1,989
Toronto,Canada
We'll be using the cabin temperature feature of the new update here in cold Canada winter, for sure, keeping the cabin warm while we leave the car for short errands will be super nice.
Won't need the details on the nav screen for supercharging power availability (max kW) as we have an "A pack" battery that only supports 88 kW max charging speed, so even the 74 kW superchargers will be plenty.
MichaelS
319
51
Hayward CA
I just got the 2017.50 update and the new version of the app. I don't see the battery warming feature. Is it supposed to be in the app?
Thanks.
MichaelS
319
51
Hayward CA
Just read the app description again. If the temperature is near freezing and you precondition the car, then the battery heating occurs. There is no separate button to enable it.
jerry33
Mar 8, 2012
19,516
21,709
Texas
At least for me, that appears to be the same as it's always been. If you preheat the cabin with the app, battery heating takes place too--at least when plugged in and range mode off. I've never preheated the car unless it's plugged in. At 3C preheating the cabin with line off (before 2017.50.2) moves the yellow line from around 15 to over 30. If the charge time ends shortly before driving, then there is no yellow line.
If preconditioning means the preconditioning setting, I wouldn't know as I've never enabled it.
Reactions: David99
dgpcolorado
Apr 25, 2015
2,476
3,281
2017.50.2 release notes:
This appeared in some earlier releases but 2017.50.2 seems to be a broader release that includes the classic cars.
I've been playing with easy entry and it works well enough, although I haven't found the best seat and steering wheel position yet. I have the seat move forward, since I sit behind the B pillar for leg room, and the steering wheel goes forward from all the way back, as well up all the way.
As others have said elsewhere, it would be nice if both happened at the same time. I do wonder if the extra wear and tear on the motors is worth it.
Reactions: SmartElectric
MP3Mike
14,978
31,853
Oregon
I've seen videos where both the seat and steering wheel move at the same time. I wonder if it is a limitation in older cars, or is moving at the same time a feature of the Model X? (I think the video was a Model X.)
Fiver
1,853
1,543
Utah
Yea my primary complaint about easy entry is the thing I need out of the way first (steering wheel) is the last thing to move. Did this flip that around?
MP3Mike
14,978
31,853
Oregon
You can see in Bjorn's new video that the seat and steering wheel move at the same time for his X:
(Time 4:27 if you want to skip ahead.)
So it must be a hardware limitation in the older cars.
