Firmware Image Request - APE HW2.0
Hi there,
I realize that this is a bit of a longshot, but I am in need of either a recent (2020.32-now) ape firmware image or a way to manually install a regular cid firmware image without an ape image on an AP2 MCU1 vehicle. If there is anyone on here that would be able to contribute, that would be great.
I just need a valid image that I can serve from my own webserver, I already have one for the cid.
I have tried updating with dashw in the config set to 0. The car will initiate an update but not progress past 10% for some reason. Sometimes it gets stuck at signature status=starting. If anyone is willing to help, I would greatly appreciate it.
Thank you.
The only main thing I can tell from the cid-updater logs is this:
cid-updater:11505: report_gwxfer_done_then_free status=closing session_termination_code=0 sid=120 fd=16 xfer_bytes_expected=1 xfer_bytes_received=1 xfer_bytes_processed=1 gateway_response=1
cid-updater:11551: GWxferWT status=success xfer_filename=hwidacq.upd xfer_bytes_sent=22
cid-updater:11494: onclose_copy_misc_status_to_parent sid=120 misc_status[0..3]=1000
cid-updater:14949: fetch_gw_file_synchronously sid=51 status=starting remote_filename=hwidacq.upd
cid-updater:14970: fetch_gw_file_synchronously sid=51 filename=hwidacq.upd pass=0 remaining_time=59.999921
cid-updater:14483: request_gwxfer_read status=starting remote_hostname=gw remote_path=hwidacq.upd local_path=/tmp/comparison sid=51 gwxfer_sid=127
cid-updater:15033: fetch_gw_file_synchronously sid=51 filename=hwidacq.upd status=complete
cid-updater:15036: fetch_gw_file_synchronously sid=51 filename=hwidacq.upd status=success
cid-updater:13007: request_gateway_reboot_for_update sid=51 boot_img_filename=/noboot.img
cid-updater:12924: send_gwcmd line=13016 sid=51 status=success latency=6.86 command=0x8 retval=080100000000
cid-updater:13039: request_gateway_reboot_for_update sid=51 status=success
cid-updater:36783: HTTP Client sid 200 using session->xfer_filename = /var/spool/cid-updater/set_dv_response-51.part-51
cid-updater:17112: parse_http_header status=notice sid=200 http_response=1.1 200 OK
cid-updater:29699: gostaged status=in_progress gateway=yes
cid-updater:30593: write_file status=error path= open=No such file or directory
cid-updater: 5887: dispatch_command status=error cmd=complete_update transition_state=fail state=ERROR
cid-updater: 5916: TIMER: schedule_cu: timerfd OD parent: 0 fd:15 dtr:-1 READY:i pending: complete_update
cid-updater:39594: sid 204 has just asked to be kept awake
cid-updater:12619: do_periodically_until period_ms=60000 timeout_ms=0 name=keepawake command=keepawake
cid-updater:39586: sid 204 (schedule_cu) wants to be kept awake
cid-updater:12837: send_gwcmd_async line=13149 sid=205 status=warning busy_command_sid=204 busy_gwcmd_sid=207 remaining_time=4.990638
cid-updater:12837: send_gwcmd_async line=13149 sid=205 status=warning busy_command_sid=204 busy_gwcmd_sid=207 remaining_time=4.889185
cid-updater:12837: send_gwcmd_async line=13149 sid=205 status=warning busy_command_sid=204 busy_gwcmd_sid=207 remaining_time=4.786302
cid-updater:12837: send_gwcmd_async line=13149 sid=205 status=warning busy_command_sid=204 busy_gwcmd_sid=207 remaining_time=1.944815
cid-updater:12837: send_gwcmd_async line=13149 sid=205 status=warning busy_command_sid=204 busy_gwcmd_sid=207 remaining_time=1.843635
cid-updater:12837: send_gwcmd_async line=13149 sid=205 status=warning busy_command_sid=204 busy_gwcmd_sid=207 remaining_time=1.742413
(REBOOTS)
  • updatefail.txt
