Firmware Upgrade Tracker
Discussion in 'Wiki' started by Wiki, Mar 29, 2015.
Tags:
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Thank gawd! I got so tired of telling people it was irrelevant. I wish someone at Tesla Development would feel the same way, as it never added anything to the conversation except confusion.
    Thanks for simplifying things. Of course, that means now Tesla will soon change back to the ‘original’ numbers the SC’s use. :D
  2. lightningltd
    lightningltd Member
    Trinidad, Ca.
    I am tesla05733 in the fw tracking tool. I also need a pin reset :p
  3. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    I've changed your handle on EV-FW to lightningltd so you can now log in or get a PIN reset using that handle.
  4. Randy Spencer
    Randy Spencer Active Member
    Alameda, CA
    I am noticing now that I have the site polling my car for updates that it claims the update occurred via WiFi, but no model 3 HAS WiFi.
    Also, how do we get rid of an entry that someone typed wrong, Someone entered they got updated to version 2018.4.19 on the 23rd. That error going to be staring at us for the entire year. It is always sorted to first in the list...
    -Randy
  5. HankLloydRight
    Connecticut
    Everything can be corrected grasshopper. ;) Do you think 2018.4.19 is wrong? What do you think is correct? They said in the note in addition: "Car delivered with 2018.4.19 installed."
    The background job assumes Wifi updates. We're really not using that attribute anymore. Updates come equally over OTA and WifI. The only updates limited to Wifi are the map updates. I added it to see if there were any patterns relating to the updates, but there are none anymore.
  6. Randy Spencer
    Alameda, CA
    The recent updates for the Model 3 are 2018.14.13, 2018.12.1, and 2018.10.5.
    I did get 2018.14.13 installed on the DATE 2018/4/19, so likely that is what he was saying. The advantage of the system polling for it automatically.
    -Randy
  7. Ebony Star
    Ebony Star Member
    Knoxville Tennessee
    What is the difference between 2018.26 and 2018.26.2
  8. HankLloydRight
    Connecticut
  9. SkiTrak
    SkiTrak Member
    Denver, Colorado
    How can you use the firmware tracker to figure out if you should have an update?
  10. BeesKnees
    BeesKnees Member
    Oregon
    I check it every few days for the existence of new versions. Lots of versions get really small numbers, so I know to not fret. The ones that ramp I then do a search here in TMC for comments. Maybe not my car configuration. Ok. If all that passes then I’m wanting it.
  11. Gwgan
    Gwgan Almost a wagon
    Maine
    Just noticed that although one can select a letter for the first of the last six items in the VIN it does not save. A number does save.
  12. HankLloydRight
    Connecticut
    Yes, actually in order to properly generate the "VIN Range" reports, the initial letters P,S,F were superfluous, and all those VINs are under 99999, so instead of storing the letter, it just replaces it with a "0".
  13. hgpayne
    hgpayne Member
    San Diego, CA
    @HankLloydRight my X identifies now as 10.1 yet the only option in EV-FW is 10.0. How does one add the 10.1 option?
  14. HankLloydRight
    Connecticut
    What FW version do you have?
  15. boaterva
    40.2.1 (at least) is called 10.1(blah blah) in the car. Interesting the app doesn’t include that part. No idea when it changed from 10.0.
  16. HankLloydRight
    Connecticut
  17. hgpayne
    hgpayne Member
    San Diego, CA
    Originally I saw 10.1 at 40.1.1. I'm now at 40.2.1 and it is still 10.1.
  18. Blissedout
    Blissedout Member
    Weston CT
    On the firmware upgrade tracker Update 2019.40.2.3 shows total updates of 126 under build-day-sx but only 18 under build-auto.
  19. HankLloydRight
    Connecticut
    Fixed, thanks.
  20. LeoBley
    LeoBley Member
    San Jose, CA
    I’m not seeing entries for 2019.40.2.3 or any firmware updates since early December. I’ve logged off and on, but no change to the reports.
Thread Status:
