First Day Owner Questions
Discussion in 'Model S: Ordering, Production, Delivery' started by base698, Mar 30, 2018.
  1. base698
    base698 Member
    United States
    Picked up my Model S with version 2018.10.6 b532133 today. Had a couple of questions:
    • The odometer still reads 50 and doesn't count up, I assume it will once it really hits 50?
    • The PSI on the tires is showing -- for all tires.
    • The WIFI is haven't trouble connecting, thought maybe that was fixed in 2018.10.6, could be my signal?
    • Where do you store the cable? Do you disconnect it every day and put it in the car? Leave it connected to your wall? How does it deal with being outside?
  2. David29
    David29 Supporting Member
    DEDHAM, MA
    Odometer should change constantly. Puzzled by what you are seeing.
  3. Tam
    Tam Well-Known Member
    Visalia, CA
    Congratulations. There's nothing wrong with that!
    Could be. You might want to get a wi-fi extender to where you park.
    If you have only one, then I would keep it in the car unless when charging.
    It's rated for outdoor so it should be fine.
  4. base698
    base698 Member
    United States
    After reboot connected to the wifi fine, but odometer still stuck though. Maybe they figured out how to make the car not put on any mileage :p
  5. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    #5 boaterva, Mar 31, 2018
    Odometer makes NO sense. It’s really not changing? I’ve seen 50 on forms but not on cars. Mine came with a low number and constantly changed.
    Tires usually only work when in motion (the pressure sensors :D).
    Perhaps you need a MCU reboot for both these issues; usual hold down both scroll wheels.
    Hm, saw you did reboot. Drive some more now that you’ve rebooted and check the tires and odometer. :D
  6. base698
    base698 Member
    United States
    Finally started counting up. Think it had some kind of lock on it to not show miles until it hit 50. Went on a drive and noticed it was 58 when I got home.
  7. boaterva
    Delivery docs always show 50. They may have changed cars to not show less than ‘delivered’.
  8. f3honda4me
    f3honda4me Member
    Colgate, WI
    For what it’s worth I picked mine up a week ago and it only had 4 miles on it.
  9. boaterva
    Yeah, that’s what I remembered on my X in September. I believe it had 10 or something. No idea what OP’s car had going on.
  10. hulk2k17
    hulk2k17 Member
    DFW Area
    My paperwork said 50 miles but in actuality I only had 10 miles on it. Regarding the UMC. I leave mine plugged in at home with the Tesla cable organizer. I was actually worried about wear on the outlet and plug connecting and disconnecting it every couple of days. I still carry around the J1772 and NEMA 5-15 adapter in the car though.
  11. Kandiru
    Kandiru Active Member
    Wow, imagine the resale value:)
  12. jjrad
    jjrad Member
    Congrats! You will love your car
  13. Sawyer8888
    Sawyer8888 Member
    South Florida
    Congratulations on your new car. I have found that Tesla's Wi-Fi is easily disrupted by certain devices in the home. It's also possible that Tesla used an insufficient Wi-Fi antenna in their cars - I never get strong signal despite my wireless router being relatively close. There are threads on the forum that go into detail on this topic.
    One of those threads speaks to the Wink home automation platform and how it interferes with Tesla's Wi-Fi, often disconnecting the car.
