LuckyLuke
Model S P90DL
I assume most sound we hear in the video comes from the dyno rollers and not from the car itself, right?
The car was freaking out with multiple error messages afterwards but they all cleared after driving for 30 seconds. It wasn't my car but was a P85.
... Shouldn't regen be causing the brake lights to remain on as the car is slowing down, or am I mistaken that the brake light behavior is not based on rate of deceleration but rather something else? ...
When I picked up my car from the factory, I was told all cars go through a dyno. Its in the back right hand corner for the test track, behind the water tank.
Someone check it out.
When my car was delivered there was a huge energy spike at the very beginning of the graph--over 1000 if I remember correctly.
Why does the power fall off so significantly as speed/RPM of the motor increases? is this physics or is Tesla dialing back the power?
Physics. The energy required to spin the motor increases exponentially as the rpm increases so "power to the ground" drops off as rpms rise - the opposite of an ICE. That's why EVs are so fun - you don't have to wind them up to get full power.Why does the power fall off so significantly as speed/RPM of the motor increases? is this physics or is Tesla dialing back the power?
A couple of weeks ago I had my Standard 85 dyno'd, thought I'd post the numbers since I didn't see any previous standard 85 numbers posted.
Have to say it was a bit scary flooring my car at a brick wall, trusting only the safety straps they put on the car to keep it from crashing. I also had a heart stopping moment when all the errors started going off.
Scared the poor guy running the dyno too. He said "Floor it.".. I said "Floor it?"... He said "Yeah." So I did. Then he started screaming "Stop." I was getting so much torque at the wheels he was afraid I would break his dyno.
When it was all said and done these were the numbers we got, rolling on the pedal.
View attachment 21287View attachment 21288
I was driving around today and I noticed that the energy output meter was exceeding 320kW by a noticeable amount at full acceleration. This correlated with my "seat-of-the-pants" dyno perception that the car seems to have power closer to 500hp than to 416hp. Because the energy output gauge is a log-scale, the actual electrical output might be closer to 350kW. Converting this direcly to hp yields 470 hp.
Sure enough, I found this thread showing 386 wheel hp, which, when the standard ICE correction factor of 18% mechanical loss is applied, comes to exactly 470 hp at the crank.
Thanks, Tesla, for the extra performance. No wonder that Porsche Turbo couldn't get ahead of me the other day!
... "WCF" ... stands for Weather Correction Factor. ..
My only question is: does this apply to an EV, as an EV at the very least shouldn't be affected by barometric pressure.
