First Electric Bill with my M3: I am saving $$$$
StellarRat
1,490
1,337
Pacific
It's costing me around 40 cents a day (so about $12 per month) to charge my Tesla at home. I have a time of use plan and electricity is really cheap in the NW. After 10 PM the cost is 4.209¢ per kWh. Also, I probably average 20 miles a day driving.
dlieu
206
140
SF Bay
i've had at least one ev (spark ev) since 2014 in the PGE territory. EVA used to be 8c off peak back then, with the prices of gas here that's 4x difference compared to a gas conterpart of the same model. Service, toll benefits are also some $. I was able to do about 3k a year savings all in all with one car (granted, it was a subcompact). Since then i also bought PacHy which additionally charges about 13kwhr daily . PacHy services are more of a regular car kind, although oil change still is just once a year. My last cycle bill (the electric part) was $115. anyhow between two cars I estimate should be at least 5k a year.
The caveat is that eva is 48c at peak starting 1 of sept. With summer AC use and EVA as is, that would easily push the bill towards $250 or more. Inner east bay is not too hot though. To cope with the peak and half-of-peak rate robbery, last year i have install 2x pw2, and now i have backup + off-peak pretty much the whole day for the house too (minus PW charging overhead for the house use during peak).
The PW investment was a bit steep for what it does though, ~13.5k which is being offset by SGIP rebate step 2 ($9280) (which i am still yet to get!). This rebate turns out to be the toughest to get yet. So the PW ordeal is probably ~$4250 net or so, which still is a bit steep for offsetting mere $600-800 a year (which may climb up though). Still though, it is also an automatic backup (we are losing power during storm season once or twice almost every year due to high winds in canyons). And now we don't care about when it is the best time to run dryer or electric oven anymore. The PW is able to offset completely up to 10kw, which is about peak oven + dryer consumption at the same time. That has to be worth something. And now i have a potential to pair it up with solar TOU in the future as well. If it weren't for SGIP, i am not sure if I really would do the PW though. Solar alone would have potential to erase my electric bills completely, but it would be order of magnitude bigger investment than the PW2, and i am not sure my house can effectively carry the amount enough for 2 evs. In the end the PW does seem like it has worked out well enough though.
Another caveat is that eva off-peak rates have been climbing pretty quickly (now 13c, so somthgin like almost 50% increase since 2014). And I think gas has eased a little bit since then, so now it is probably more like 3x less cost vs. gas, probably closer to 3x.
With M3 i expect the bills to go up a bit, as M3 is usually not as efficient as spark ev (i usually am able to drive between 4 and 6 miles easily per kwh with Spark).
The cost of M3 alone should make all these savings pretty laughable though. But most importantly, in the end one cannot quite put a cost on air quality, so I don't worry if I end up coming higher or lower. I am more inclined to view it as a personal contribution to stopping emissions. Bite the bullet once, enjoy a cleaner neighborhood for years to come.
30
51
Marion, Indiana
I think something is not right with either the miles driven or the power usage. If you use 835 kWh to charge the Model 3, you should have well over 3000 miles. If you only have 2065 miles, that will put you at 404 Wh/mi. Even if you add in AC usage, charging lost, and other stuff, it still seem pretty high?
My car used 565 kWh, however my increase in my bill was 835 kWh. I used the higher amount in my estimate.
North75
595
723
MA
Yeah so I think it is not really 835 kWh, should be closer to 600 kWh. Not sure where the other 200+kWh went this year.. maybe AC? Hotter this year at the same time?
I'm not so sure. I've been seeing pretty large increases in my electric usage vs. what one would expect if only looking at the miles driven and reported Wh/mi.
Obviously this is hard to quantify because the other loads in the house aren't constant year over year, but I think there is a fairly significant amount of shore power used by the car when plugged in. I've noticed the green lights on the HPWC indicating that power is flowing when the car is not charging (charging is scheduled to start later at night)
I also think that the car itself uses more power when it is parked that is not indicated in the Wh/mi numbers reported in the odometer.
I'm not really up for fully tracking how bad this, but hopefully someone else will take this effort on.
I need to remind myself I didn't get this car to save money. I'm pretty much in a worst case scenario anyway. I live in a state with very high electricity costs, but not particularly high gasoline costs. I also work from home, so I don't drive much, and a lot of the driving I do is short distances which I think is generally pretty inefficient. Leaving my old ICE sit really didn't use any energy. I typically used to purchase gas about once every 3 to 5 weeks.
Love the car though. We've taken it instead of our SUV on a few road trips because its more fun to drive and the Autopilot is great. I've managed to put 3500 miles since mid June even though my typical work day average is less than 5 miles.
David L
323
454
San Diego, CA
I'm waiting for someone in SDG&E territory w/o solar and not on EV-TOU-5 to do the same analysis and realize that they've just nicely padded Sempra Energy's bottom line. :p
Eno Deb
2,599
3,153
SF Bay Area
Seriously. Here In ca. I think my electricity equalivant is same as gas!
Yes, I doubt I would save anything if it wasn't for workplace charging. My employer has some kind of corporate bulk rate which is about 10c/kwh and they pass that rate along to us EV drivers. The residential rates around here are much higher. I'll look a little closer at the EV TOU rates when I have a better grasp how much energy I use to drive, but given the ridiculously high peak rates (40-50c) I doubt it'll save much.
dlieu
206
140
SF Bay
yes, you need either more mileage/cars to charge, or negligible house use (AC in particular), or time-offset it with PW or similar (or all of the above :) But yes it can be amazingly efficient. I get typically $120 monthly electric bills for about 1MWh use.
ℬête Noire
3,105
2,556
TX
When I read how little you guys are paying for electricity I weep. :confused:
Turn that frown upside down! Think about how much longer it takes for me to pay off my solar install. :p Ballpark estimate is more like 12-13 years compared to a lot of Californians being able to recover full price in 3-5 years.
Need more time to get a full and proper accounting of it all, especially the solar because I want to run a full year to really feel confident since it's relatively tight margins there. However the step to one EV (used for most of the miles) was definitely over $200/month drop in gasoline -> electricity costs shift. The 2nd EV won't be quite as much, maybe another $40-$50 for a total nearing $300/month. The extra $30/month in issuance for the Model 3 is offset by oil change etc. visits.
ℬête Noire
3,105
2,556
TX
Now start bawling. I get free electricity at night from TXU. The cost to run my Tesla - $0
It's a trap!
Well maybe not if you're using enough miles versus your early evening AC usage. Are they still charging 13c/kWh in the daytime on that plan?
It's the roughly 7c/kWh that some people are realizing over the month using Griddy that's really crazy. I wish Griddy had a buyback plan I could use on my solar, I'd clean up.
Electroman
6,114
6,167
TX
It's a trap!
Agree with your point. what I conveniently skipped is the fact that my day time rate went up by 3c/kWh. But since no one is at home during day time, I keep my AC at a higher temp during day, and shift all of the electric workloads to night, like laundry, dishwasher and Tesla charging. So with careful planning my bill has come down by 20% from last year.
So this won't be a win-win for everyone.
privater
2016 Model S and 2017 Model 3 owner
Jun 22, 2016
254
735
What's even better is you can generate power through solar and off the grid, you can't refine your own gasoline. ;)
SageBrush
REJECT Fascism
May 7, 2015
12,084
14,993
New Mexico
EV + PV is a great combination.
I pay about 0.5 cents a mile to run our EVs from the PV in my backyard
Compared to an average ICE that gets around 27 mpg, the EV is 10 cents a mile cheaper to run. If the Tesla lasts 200k miles, it works out to $20,000 fuel savings.
woodisgood
It's walnut, beech
Jul 26, 2018
2,190
9,808
San Francisco
Coming from a 2008 Acura TSX, with 550 mi/wk commute, 27 mpg, premium gas around $4/gal = $325/mo.
30 day cost to charge Model 3 = $85. (0.13 off peak electricity rate)
Saving ~$240 per month. Of course there was no car payment with the TSX, but that $240 savings makes the net Model 3 payment so much easier to swallow.
ebmcs03
2,116
1,066
So Cal
How much does it cost to run your house now? Since your day time rate has gone up significantly.
ebmcs03
2,116
1,066
So Cal
make sure charge at night during off-peak hours with EV plan. It's 1/3 cost to me.
It’s still not cheap here for Edison.
I don’t like TOU because it drives the rest of the days energy cost through the roof! Basically all my normal house useage will be 3X as much. Then I add on $0.12 a kw for night time car charging.
It’s technically cheaper for me to charge at a chargepoint station at $1.25 ah hour which comes out to $.21 a kw.
woodisgood
It's walnut, beech
Jul 26, 2018
2,190
9,808
San Francisco
Yeah the TOU plans really depend on your daytime or peak usage. We were able to shift most electricity hungry appliances to offpeak times (washing machine, dishwasher). Other appliances including heat are gas. No A/C here. Mostly LED lighting.
So cost to run house is about the same or might have even gone down slightly with behavior change.
Reactions: SageBrush
