First impressions, Model X versus 3 year old Model S
Discussion in 'Model X' started by Cosmacelf, Jan 1, 2016.
Tags:
  1. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    Yeah, if I knew I wasn't going to need 7 seats from time to time, that's what I would have done - just gone with 6. The middle seat is a bit compromised in that you can't sit there and use the second row cup holders at the same time. I haven't seen a 6 seat config, but it would seem to make sense that you'd have good access to the third row without the middle seat.
  2. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    Great writeup. Is the air suspension not able to adjust your ride comfort as well as height? Perhaps you have not had a chance to try various stiffness settings yet?
  3. Cosmacelf
    San Diego
    I went with 20" - I had 19" on my Model S. Yes, seats are white, they feel nice, supportive. Who knows how well they will hold up! I've got kids, so I'll be putting them through the torture test...
    - - - Updated - - -
    Yeah, the Model S rear view wasn't great, the Model X is worse. Not very useful since you don't know what you're missing as far as being able to see or not see.
    - - - Updated - - -
    Does it have stiffness settings??? I haven't seen that...
  4. AMN
    AMN Member
    Minneapolis, NYC, Bozeman
    Thanks for the review! How was energy consumption during your 500-mile drive back?
  5. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    #25 ohmman, Jan 1, 2016
    So as a point of reference, I have an 8' ceiling but my garage door itself is at 7'8". The rails for my door are at 7'3", and those would be the lowest obstruction for the doors. Next time you're out there just chilling with a tape measure (!) and feel like stopping the doors a few inches shy of your door (7 footish), I'd love to know how much clearance there is under the door. You know, just in your free time. :roll eyes:
    I'm going to add your reference to the garage doors thread I started a while back, FYI.
    Edit: This one's easy - did the doors stop early in your garage, or were they fully opened?
  6. Larry
    Larry Member
    East Bay of SF
    Thanks for the thorough write up. My question is in comparing the S to the X is the X a lot easier to get in and out of from the drivers seat? I'm tall with creaky knees and the S is a little bit of an issue when getting out.
    Thanks
  7. Cosmacelf
    San Diego
    #27 Cosmacelf, Jan 1, 2016
    The FW doors do stop early in my garage. Still lots of space under the doors, so if they had to stop even earlier for a lower high garage, I think it would be fine.
    Btw the front doors are pretty cool. They have infinite detents meaning that that they stay open at any angle as opposed to most cars that have just a few open positions. The software doesn't yet auto open upon approach but they have a cool auto close feature. Just press on the brake in the drivers seat and it closes.
  8. moviemaker2000
    midwest
    Do you think they are stopping because they detect the rails, or the black "J" shaped bar that pulls the garage door up and down that hangs a couple of inches below the rail? I am wondering what would happen if the kids open the FWD in a closed garage and then someone puts up the garage door opener while the FWD are in the open position. Would the FWD be low enough so the black "J" shaped bar on the garage door doesn't scrape across the open FWD as the garage door moves up the track?
  9. rdalcanto
    rdalcanto Active Member
    Salt Lake City
    If someone opens my garage door after the tailgate on my Jeep is open there will be serious damage. It would be pretty careless to open a garage door if the FWD are up. Most likely the design of your garage will determine if the FWD open high enough to be hit by a garage door opened after the fact.
  10. moviemaker2000
    midwest
    It has happened several times where the kids are getting in one car in the closed garage because of the cold weather and the other driver is arriving home and opens the garage door while pulling in the driveway not knowing someone is loading into the other car.
  11. Cosmacelf
    San Diego
    Another thing I noticed today while driving around - the default ride height is higher than the Model S ride height - there is more ground clearance. Places that I would have scraped the bottom of the Model S are clear on the Model X.
  12. SMSMD
    SMSMD Active Member
    Edmonton, Alberta, Canada
    Was your air suspension at low, high or very high at this time.thanks for your excellent information.
  13. ohmman
    North Bay, CA
    One thing you can do, assuming your garage door is properly installed and moves smoothly, is mess with the tension control on the opener. It's possible to make it very sensitive to resistance, and damage would be pretty unlikely.
    My 1970s wooden garage doors sadly require quite a bit of leeway in tension control because they hang up here and there. So I don't have as much wiggle room on that front. I still doubt there'd be much damage. Just put your hand in the way of the door while it's opening and see how much it takes to reverse.
  14. mikevbf
    mikevbf Active Member
    vermont
    I am surprised to hear this about the frunk. i thought the Model X was supposed to have a larger frunk. Do you think the non performance version will have a larger frunk? I am glad to hear about the extra space around the seats in the second row. Since I will also end up with the 7 seat version, I am sure I will use this on longer road trips quite often. Thanks for sharing such practical comments with us all.
  15. Cosmacelf
    San Diego
    The default appears to be low on the Model X. There is also a very low setting, but that only occurs at speed.
  16. SMSMD
    SMSMD Active Member
    Thanks that great news.
  17. Cosmacelf
    San Diego
    Well, the Model X has a larger frunk than the tiny Model S dual motor frunk, but it isn't as large as the original Model S frunk, as that also had that hidden cube storage towards the driver.
    - - - Updated - - -
    No doubt awful. I drive fast (even with autopilot) and temps were from 32 to 45.
  18. SMSMD
    SMSMD Active Member
    Thanks again for very very useful info you are posting and answering all our questions.When you have time and if you can post photos of the trunk/Cargo space will be very much appreciated...I saw some from Bonnie's photos of Low, flush and high positions of trunk space but could not appreciate the potential space within. I have 3 Kids and cargo space is very important. I am thinking of Thule transporter 665C to the tow hitch if need be. Frunk is always a bonus in tesla.
  19. ankitmishra
    ankitmishra Member
    India
    Congrats!! Thank you for helping people out and explaining about the car. It makes an interesting topic to read.
  20. DaveT
    DaveT Searcher of green pastures
    San Diego
    Hi Cosmacelf, can you talk some about the driving dynamics of your X vs your P85? Does the increased height and weight of the Model X compromise the handling at all (vs your P85)?
