Cost was around $24k (before incentives) and financed the whole system on a 10 year loan(20 yr loan is also available but not while financing the battery) which puts me at a little over $200/month. I'm planning on paying it off earlier though.
Per watt, that's cheaper than SolarCity's quotes in California *without* battery storage! I understand that electric rates are much lower in Texas than in California, so perhaps SolarCity/Tesla has to charge less to remain competitive.
I have one question if you wouldn't mind. My understanding is that whenever the grid goes down, your surplus solar production (whatever isn't being used to power your home) will be used to charge the PW2. However, your 7.56 kW PV system will, at midday, generate more power than the maximum charge rate of your single PW2, which is 5 kW. Did SolarCity explain what will happen in that scenario? I am wondering if the PV system would need to disconnect, in which case the battery wouldn't charge at all.
I'm asking because I'll be in the same boat, with an existing 6.48 kW PV system and plans to install a single PW2.
