First Stone Chip... Tips for Touch Up Pen?
Discussion in 'Model S' started by hingisfan, May 15, 2015.
Tags:
  1. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    Got my first Stone Chip right in the middle of my hood. I have standard white with no after market coatings. I picked up the touch up pen when I bought. Any tips for best results?
  2. paintpolisher
    paintpolisher Banned
    Atlanta, GA
    Clean area and wipe w isopropyl alcohol. Use as little paint as possible. Dry w hair dryer and add a little one more time.
  3. William13
    William13 Active Member
    South Bend
    1 shake pen well
    2 purge the color first onto a clean surface (cardboard)
    3 use a flat toothpick to apply color
    4 be ready to remove paint immediately if not satisfactory
    5 repeat until satisfied. This is permanent paint.
    6 Xpel Ultimate will prevent more than 9 out of 10 of the small chips.
  4. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Apply two to three layers of touch up as above until the dried surface is above the rest of the painted surface. Let dry 24 hours minimum, then lightly use 1200, 2000, then 3000 grit sandpaper to finish to the existing surface. Use aggressive polish, then finishing polish (I like Mcguiars numbered finishing products) and wax to match the existing paint.
    http://www.wikihow.com/Touch-Up-Car-Paint
  5. JPP
    JPP Active Member
    SF Bay Area, CA
    ...or look into Dr. Color Chip. Nice system, good color match, fills chips well. You will likely need your 4 letter color code when ordering.
