Did the first tire rotation (front <-> rear) at ~6,500 miles. Discovered a few things:
- With jack pucks in the jack point holes, my trolley jack is too high to fit under the jack pucks. I had to back the car halfway up some ramps in order to make the clearance to jack it up at the rear jack point with the jack puck.
- The jack stands that I have are too high to fit under the front jack point. Not completely required (since I was not going under the car), but I would have preferred to be able to put a jack stand there as an additional safety measure.
- 129 lb-ft is a higher wheel nut torque spec than most cars. The 150 lb-ft torque wrench that I have is not that long, so a 250 lb-ft torque wrench with a longer handle would be better.
- The torque wrench barely clears the car with a normal 21mm socket on it. A deep socket would be better.
- Before rotation, the front tires measured 8/32" tread (basically new), while the rear tires measured 7/32" tread. With rotation, that indicates about 1/32" wear every 13,000 miles, so the tires should last about 52,000 miles until 4/32" (after which I would replace when the next rainy season comes) or 78,000 miles until 2/32" (the legal minimum). Without rotation, the rear tires would probably be down to 4/32" at around 26,000 miles, and down to 2/32" at around 39,000 miles. However, these are not precise estimates; it may take more mileage and tire rotations to get better estimates. Your tire mileage may vary. If you do a lot of hard acceleration, you may want to rotate the tires more frequently.
- Does the car automatically discover the tires' new positions for TPMS purposes?
- What easier and/or better jack and jack stand solutions are there that are not excessively expensive (i.e. do not want to have to install a shop lift in my garage)?
