I only use summon as a demo for a new audience and not for my own practical daily use because it's just way too much slower than manual drive. May be it will be better than human in future but not for now.
...a little more forward/backward...
I use it daily. My garage is tight so it's hard to get in and out of the car with out hitting a wall with the doors. I painted lines on the floor so I know if I'm lined up, but I still watch it like a hawk.
I stick the tape on the floor as a marker so that I know when is the perfect stop just by looking the rear view camera.
We have the same now (the mount on the front wall ones) and will definitely need to use Summon when we have an X and a 3. Modern normal garages are not made for these cars.Pssh! That's old school.
My garage opener has this laser beam add-on that is mounted to the ceiling and points down, when the red laser dot hits a certain spot on the dash, I know it's perfectly positioned.
Wow, that was quite disappointing. I kept hoping it didn't lower your garage door on your car.... I'm pretty shocked to learn that this feature hasn't been perfected, as it's been out for quite some time.Tried using Summon to front and reverse park my P100D in the garage and got mixed results:
Any tips?
P.S. Ignore my comment about the car recognizing the location of the key and needing to be outside the garage.
I do wonder sometimes if my great success with it, as opposed to others frustrations, is because I back-in verses pull-in.
Are you from the future?My garage opener has this laser beam add-on that is mounted to the ceiling and points down, when the red laser dot hits a certain spot on the dash, I know it's perfectly positioned.
Sorry @NewTMSMan , I wasn't meaning you specifically, just in general with others, I've found that it tends to work better getting in and out of the garage being backed in.As you can see in the video I tried backing it in too and had to try more than once to get it in. It may be due to the ridge in my garage floor, but it is <1", which is on the lower side for a garage floor in the US. Might see if I can install some kind of entry to bridge the garage floor height. Main reason I want to use this is my wife is not great at pulling in to the garage and would be good if the car just did it.
