Fit of HPWC Cable Organizer
Discussion in 'Model S: Battery & Charging' started by bob_p, Nov 8, 2013.
  1. bob_p
    bob_p Active Member
    At least with the version of the black HPWC cable organizer I received, the charging cable fits loose into the organizer, and can easily fall out.
    A quick and easy solution was to add two strips of black cloth (the cloth side of a Velcro strip) on either side of the cable organizer opening - and now the cable fits snugly in the opening - and isn't as likely to fall out.
  2. ACDriveMotor
    ACDriveMotor Member
    Seattle, WA
    I've noticed this myself. I use the HPWC organizer for my UMC. Inside the opening? Can you post a pix?
  3. PhilBa
    PhilBa Active Member
    Seattle
    Yeah, that's the way it is. My sits crooked but stays in because the pressure from the cable pushes it up and prevents it from coming out. Looks pretty amateur.
  4. Forty Creek
    Forty Creek Member
    Carlisle, Ontario
    I just gave up and let the end dangle.
