I have a 2020 Tesla model 3P. I am running after market 18 inch wheels with 255/40 tires. I wanted to push the wheels out away from the control arm at the front but I wanted to keep the stock studs on the hub so the thick 15 mm spacers from Blox were out of the question. I found these great 5 mm spacers that fir perfectly. You don’t even have to remove the hex screw on the hub. They are for Nissans but they work on the model 3 Performance https://www.amazon.com/dp/B01LXLJ5G1?ref=ppx_yo2_dt_b_product_details&th=1
These are not for looks/stance because they are only 5 mm. They just give the wheel/tire more clearance from the control arm. They can also be used on the stock 20 inch wheels and that will increase the offset from +35 to +30. My current 18 inch wheel set-up is at +40.
