Fix for Roadster 80A Charging Bug
Discussion in 'Roadster' started by tomsax, Nov 7, 2013.
Tags:
  1. TEG
    TEG TMC Moderator
    #121 TEG, Jul 29, 2014
    I think the pilot signal reader circuitry has trouble getting a clean reading when the "off" phase is so short above 70A.
    Not much room for error on the 80A signal...
    80A duty cycle is right on the edge of triggering an error condition...
    Precise measurement starts to become more important.
  2. hcsharp
    hcsharp Active Member
    Vermont
    Hard to believe that would be true. It's still a very long pulse (on or off) compared to many other signals that the car has to read. A measly 4mhz microcontroller costing less than $1 can measure that with very high accuracy.
  3. slcasner
    slcasner Member
    Sunnyvale, CA
    Which is a real shame when I show up with my Roadster needing to charge so I can continue on to Santa Barbara.
  4. TEG
    TEG TMC Moderator
    I think that some of EVSEs may be putting out a sloppy waveform that doesn't pull as high and low as it should. I haven't measured it myself, and am just relating some things I heard secondhand. I think the "fix" is to change how the algorithm decides what is "on" and what is "off".
  5. Curt
    Curt Roadster Signature #55
    Rockville, MD
    TEG - this is certainly true. I was at the Electric Sociability Run in Charles Town, WV a couple of months ago. The site has 14 Schneider Electric EVSEs, and not one of them would work with my Roadster (1.5). Other EVs, including Model S, had no problem.
    There were some guys from Merit Solar there. They hooked up their testing equipment, and found that the pilot signal was out of spec on every one of the 14 stations.
    Fortunately, they had brought along one of their portable EVSEs, and we were able to tap into a circuit at the Civic Center, giving me enough charge to to get through the day's activities and get home the next day.
    I have since found two other locations with Schneider Electric EVSEs which would not work with my Roadster.
  6. djp
    djp Roadster 2.0 VIN939
    Toronto, Canada
  7. TEG
    TEG TMC Moderator
    I think that is more of a ground fault detection issue, not necessarily an issue with the pilot signal.
  8. chrisro
    chrisro Member
    Germany
    Does anybody seen how they update roadster? Which cable, software? How long it takes?
    cheers
  9. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    It is a firmware update. Mine was done during a Ranger visit of about 10 min.
  10. chrisro
    chrisro Member
    Germany
    Thanks, but I would like to know more technical side.
  11. TEG
    TEG TMC Moderator
    I think that they may have to open up the PEM and plug in a special firmware updater device (laptop) to program in new firmware.
    I don't know anything about the versions involved.
  12. chrisro
    chrisro Member
    Germany
    Thanks for reply. They are not doing this by can bus connector?
  13. TEG
    TEG TMC Moderator
    I am not totally sure about that... sorry.
  14. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    They use a laptop running Tesla proprietary software, connected to the DIAG port in the footwell (not the OBDII port, but the DIAG one). The firmware update is performed over the CAN bus.
  15. gregd
    gregd Active Member
    CM98
    I'm surprised that a car that's been serviced has not already had the latest software installed. This fix was issued years ago.
  16. chrisro
    chrisro Member
    Germany
    thanks
    what software is used ? MTS-2 ?
    do you have screenshot?
    Chris
  17. markwj
    Hong Kong
    I am not sure if they use anything more modern now, but the stuff I know of is all perl scripts with some basic curses based UI.
