Flashing HighBeam by accident when trying to start autopilot
Discussion in 'Model S' started by Rborhani, Jun 13, 2018.
  1. Rborhani
    Rborhani Member
    Usa
    Does anyone else flash their HighBeam, frequently, by accident when trying to engage the autopilot? The location of the autopilot lever, directly bellow the HighBeam lever, is, I think, annoying.
    • Funny x 4
  2. richrootes
    richrootes Member
    North Vancouver
    No, the Autopilot lever is much smaller making the two easy to distinguish
  3. croman
    croman Active Member
    Chicago, IL
    No, sorry, the stalks look and feel different. One is stubby (AP), the other full length and positioned opposite to the gear selector for AP Model S vehicles (non-AP have the gear selector and lights stalks switched but I've never encountered that config).
    I've had other issues but not that one due to the look and feel differences. If you use auto-brights, I think you can avoid this problem.
  4. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    In my experience it's easy to tell if you grab one and then the other, but if you put your hand in place quickly from position memory, you will occasionally be interfacing with the wrong stalk.
  5. SSonnentag
    SSonnentag Rocket Scientist
    Arizona
    It's been a couple of months since I flashed someone instead of activating AP. So I guess it took me 4 months to learn which lever to instinctually grab.
  6. araxara
    araxara S-P85#3,218 X-LR M3AWD
    Tucson, AZ
    This happens to me occasionally on my Model X, but it's only due to the fact that my 2012 Model S has the cruise control and turn stalk reversed from the Model X.
  7. thefortunes
    thefortunes Active Member
    Wisconsin
    Pics or it didn't happen ;)
    • Funny x 3
  8. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    No one wants to see that...
  9. Carl
    Carl Supporting Member
    Belgium
    The levers (the same ones Mercedes uses) are now in the same position as they always have been in a Mercedes (i.e. AP/TACC lever below lights lever). From 2012 to 2015, Tesla mounted them "the other way round". Anyone having traded in a 2013 MS for a 2016 MS undoubtedly had a few weeks where other drivers would think they were aggressive macho's (whereas they were only trying to engage TACC :))
  10. BillFres
    BillFres Member
    MY main problem is getting into my wife's BMW and turning on the windshield wipers when I want to shift into reverse....
    Bill
    • Funny x 2
  11. mknox
    mknox Well-Known Member
    Toronto, ON
    Yep. My 2013 S that I traded in on my 2018 X are opposite. You know what? I thought it was weird when I bought my S but got used to it and think I actually prefer the turn signal stalk lower like it was on the earlier cars.
  12. ASUComputerGuy
    ASUComputerGuy Supporting Member
    Raleigh, NC
    That's okay, I think I have you all beat: I accidentally tried to put the car in Park while on AP going 70 mph. It was my first road trip with my, then, new Tesla and I was trying to change lanes to the left. AP and TACC both disengaged, but no other harm came from it. I would not suggest trying it, despite nothing bad happening. I felt like a dotard. :rolleyes:
  13. mknox
    Toronto, ON
    I was actually quite worried about that when I first got my 2013 S because the shifter stalk was in the exact same place as the windshield wiper stalk was on my last car, and you pressed the end of that stalk to give the washers a little squirt which I have to do regularly in the wintertime on salt covered roads. It turns out I never had that problem.
  14. Black/Black MS
    Los Angeles
    Today I turned on my windshield wipers trying to adjust the follow range...not for the first time.
  15. MS_Dream
    MS_Dream Member
    Zephyrhills, Fl
    It took several months for me to get used to this Mercedes E-Class setup. Sometimes I still have to correct myself before actually pulling the levers.
  16. J__T
    J__T Member
    Broadlands
    Happens to me sometimes when I get my Model X back from service after driving Tesla’s Enterprise rental for a few days!
  17. Tdriver
    Tdriver Member
    Palm Desert, CA
    Are we supposed to use AP only on well marked divided highways? if so, why is this an issue worth talking about.
  18. BerTX
    BerTX Supporting Member
    Texas/Washington
    I have done it. I just wave at the driver I flashed.
    Worse, and much more dangerous, are the times I have Resumed TACC (often set to 75 mph) when I intended to use the turn signal going into a parking lot entrance.. Very terrifying in my MS75D, I can't imagine it in a P100D.
  19. .jg.
    .jg. Member
    Weston Super Mare, England
    I sometimes flash, instead of activating TACC or indicate left or right, instead of adjusting the speed. However, my biggest problem of late has been when I travel abroad on business and use rental cars: I keep walking away from rental cars with the keys in the ignition and the doors unlocked.
  20. Rborhani
    Rborhani Member
    Usa
    But it makes you look like a DB when you flash the car in front of you for no reason.
