Flat panel led garage lights
Discussion in 'Off Topic' started by Merrill, Jan 3, 2015.
Tags:
  1. Merrill
    Merrill Active Member
    Sonoma, California
    Just finished converting my old florescent garage lights to flat panel led lights. Much more even lighting and no funky plastic lens to deal with, plus bright even light and saves energy. Had to recess the lights and build a frame around them routing a small edge that the lights sit in that gives you a nice flush mount look.
  2. mspohr
    mspohr Active Member
    Interesting. Could you give us more information on the source and cost of the lights and well as some closeups of the lights themselves.
  3. tomas
    tomas Only partially psycho
    Chicago/Montecito
    Wow, how does your car stick to the ceiling!
  4. TEG
    TEG TMC Moderator
    Image showed as upside down for me. Here is is flipped back:
    Looks nice.
  5. Merrill
    Sonoma, California
    They are 12x48x1/2 I purchased mine from a local Bay Area source called LED Wholesalers, but you can find them at the Home Depot and they are made by Pixi and cost $189 each, but from LED on Amazon they are $125. At tad expensive but should last forever and use less electricity.
    - - - Updated - - -
    Not sure why the picture flips.
  6. GreenT
    GreenT Member
    Here
    Picture flips because you're uploading from an Apple iPhone. Right?
  7. TEG
    TEG TMC Moderator
    I am guessing that these are using a technology similar to the backlight in recent LED flat panel TVs.
    They have a bunch of LEDs all around the edge pointing into a flat "light guide" panel that lights up and glows in a uniform way.
  8. Merrill
    Sonoma, California
    Using an ipad
    - - - Updated - - -
    I thinks your correct they call them edge lite panels
  9. TEG
    TEG TMC Moderator
  10. GreenT
    GreenT Member
    Here
    That's the problem. Anything Apple is buggy.
  11. bxr140
    bxr140 Active Member
    Bay Area
    Love it. What's the lighting output compared to flourescent tubes?
  12. markb1
    markb1 Active Member
    San Diego, CA
    Everything else is buggy, too. In this case, I don't think the bug is on Apple's side.
  13. Knobby
    Knobby Member
    Ottawa, ON Canada
    It's not a Apple bug. He held the iPad upside down. That is easy to do. I do it all the time cuz I'm a lefty. But the iPad knows that it was upside down so it tags the photo with the appropriate orientation. Browsers and picture viewers that bother to check the tag know it and do show it the right way. So really if anything it is more of a PC browser bug for not checking orientation tag.
  14. Merrill
    Sonoma, California
    50 watts, 5000k and 3400 lumens, more white light than the 2 40w flourescent tube I had before. 34000 hours life.
  15. GreenT
    GreenT Member
    Here
    If it's not an Apple bug, why doesn't it happen on any Android?
  16. jerry33
    Texas
    It's not a bug it's the encoding. Not every software package recognizes every type of encoding, and picks up on the rotation. This can be proven because it always shows correctly on Apple applications.
  17. Merrill
    Sonoma, California
    I have been holding the iPad horizontal when taking pictures, I wonder if I hold it verticle and take the picture it will transfer in the correct position?
  18. omgwtfbyobbq
    omgwtfbyobbq Member
    Southern California
    I've seen some tube replacements too that are pretty inexpensive. They aren't flush mount, but they last forever and provide a lot of light.
  19. Merrill
    Sonoma, California
    Yes I looked at everything on the market and until you see the light dispersion on these flat panel LED lights you will then understand why not only is the light bright and even, but never have to replace them and use less electricity.
  20. EXOTIC1
    EXOTIC1 Member
    MANY PLACES
    well done
    kudos
