Flat--slime failed + Tesla roadside service is awesome
DingDingDao
82
0
Orange County, CA
Got a low pressure warning on the freeway and limped to a gas station. I had a slime repair kit (similar to the Tesla tire repair kit) that failed to reinflate the tire, so I called Tesla roadside service. They had a flatbed to me in 15 minutes and an appointment with America's Tire and a fresh ExtremeContact 245/35-21 setup for me. They are awesome. On the flatbed and on the way...
ZBB
Emperor
Feb 27, 2013
1,543
267
Scottsdale
For FYI, Slime doesn't actually re-inflate the tire. Its just a goo that fills and seals the leak... You still need a compressor to re-inflate the tire.
DingDingDao
82
0
Orange County, CA
Yeah the slime kit I have includes the compressor. Couldn't increase pressure above about 25psi and it would fall once I turned it off. We'll see how bad the puncture is once I get to the tire shop.
DingDingDao
82
0
Orange County, CA
Update: the tire had a nail embedded in the inner sidewall. Tire guy told me slime wouldn't have saved me with the position the nail was in. New tire installed, and I am very impressed with Tesla roadside assistance.
green1
4,548
1,121
Calgary, Alberta, Canada
My understanding is that the slime will handle a small puncture to the tread area, but not much more. Personally I'd choose a patch kit instead of a slime kit for a couple reasons. First you can use them as permanent repairs (I know they say not to, but I've never had an issue doing so), second, you can actually deal with larger holes, and third, if your tire is patchable by a professional, you won't be pissing them off as much as they don't have to clean the slime out first..
tga
3,866
2,678
New Hampshire
Is your TPMS sensor OK? I thought slime gooped up the sensor and blocked the air inlet hole(s), effectively killing it.
DingDingDao
82
0
Orange County, CA
Yeah he pretty much said what you said -- puncture in the sidewall is pretty much a death sentence for a tire, and slime kit won't save it either. I apologized for sliming the tire, too--he was a good sport about it :tongue:
- - - Updated - - -
Yeah the TPMS sensor was actually fine. He warned me that the slime might have screwed it up and that I might have to buy a new one, but once they unmounted the tire and had a look, everything was good to go.
delanman
DESpaceX
Nov 30, 2013
133
64
Delaware
Good idea for an extreme emergency. Without a jack, it might be hard to deal with a hole. I'll throw a plug tool and plugs in the frunk anyway.
green1
4,548
1,121
I just bought one at our national chain of automotive/hardware stores ("Canadian Tire") the ones I'm thinking of come with a bunch of cords about 4 inches long that look like they're a piece of string covered in tar, and two tools, one is a round file, and the other is like a needle for inserting the cord.
They do state that they're not for permanent use, however I've never had a patch fail before the tire wears out, and I've never followed up with a tire shop.
snellenr
422
640
Northern Michigan
The plugs all seem about the same. The real difference is in how well the rasp and insertion tools stand up to going through the tire. It's a good idea to throw in a pair of locking pliers in case the handles break off or bend.
green1
4,548
1,121
Never had that problem, but that's an essential tool anyway, actually a good pair of needlenose pliers is essential. This is how you remove the screw you ran over so that you can put the plug in...
Haggy
188
31
Fremont
I've patched 5 or 6 tires now, and I've never jacked up a vehicle or taken off a tire to do so. Roll the car forward or backward to where you can work on it, plug, re-inflate, drive.
Patching and plugging are two entirely different things. Patching requires taking the tire off the wheel, placing a patch on the inside, remounting the tire and balancing it. Many tire manufacturers recommend against plugging. The rule when I was younger was that it's OK to plug a tire unless it's a radial tire. But that would include about 100% of passenger car tires these days. I've plugged tires when tire shops wouldn't fix them for whatever reason. Chances are that the tire manufacturer will give you a safety warning and possibly void any warranty.
DingDingDao
82
0
Orange County, CA
Question -- do you know if a plugging a puncture is permanent, or can a tire shop reverse the plug and put a proper patch in? I guess I'm wondering if I can plug in an emergency so that I can get to a tire shop on my own and then properly repair the puncture and avoid voiding the warranty.
green1
4,548
1,121
A plug is a type of patch, and yes, they are theoretically "temporary" and every tire manufacturer will tell you not to do it. We're talking in relation to roadside repairs here though, so obviously "patching" by your definition, would simply be impossible. If "plugging" then there's no need to jack up the car.
- - - Updated - - -
Plugging is not permanent and a tire shop can reverse it to put a proper patch in. That is what every tire manufacturer, and the people who sell the plug kits suggest.
That said, I've never seen any good reason to do anything further once you plug a tire. Worst case is that the plug fails (has never happened to me in tens of thousands of km of driving on plugged tires) and you have to plug it again.
stopcrazypp
9,880
4,806
I will say however, if the issue is that the plug leaks (I had a mushroom plug installed by a previous owner that failed) and you take it to a tire shop with the failed plug still in it, they might not agree to fix it (esp. if they offer a guarantee with their tire patches and if the proximity to the sidewall is too close for a patch).
The plugs sold in stores are just sticky ropes. They can be pulled back out with a plier or pushed in and removed from the inside if the tire is taken off the wheel. But like green1 says, it's quite common for this "temporary" fix to last the life of the tire and in the worse case of a failure, you just need to do another plug. I will add however that if the damage is on the sidewall (as in the OP), a plug would not be an option (even a patch won't work).
green1
4,548
1,121
If it's too close to the sidewall, it won't matter whether you plugged it or not, they probably won't agree to fix it. The fact that you plugged isn't the problem there.
If your sidewall is damaged, you have two options for side of the road repair:
- a spare tire.
- a tow truck.
Slime will likely be useless. A plug kit like I'm talking about can theoretically do an extremely short term fix in some limited situations. High probability that it won't work, but sometimes you've got not much to loose and I have heard of cases where the plugs do fix small sidewall holes just long enough to limp to a tire shop. If the sidewall is damaged I would never consider continuing to drive on that tire any further than absolutely necessary.
