Everybody reading this thread.. do yourself a big favor and go immediately order a $20 tire puncture plug kit off Amazon. Keep this kit + air compressor in your Tesla at all times. As many people have pointed out Teslas tend to have a lot of tire issues, most of them being punctures. This is an incredibly easy repair you can do yourself, in about 2 mins and you do not need to remove the wheel from the car to fix this. I ran into the same issue, luckily wasn't far from a used Tire shop and they plugged the tire in a couple of mins and only charged me $10 for the fix.
- Find a safe place to park
- Make sure to drive the car forward/back enough where you can easily access the nail/screw (helps to turn your front wheel, if it happens to the front)
- Remove the nail/screw with some pliers
- Immediately clean up the actual puncture area with the file tool (leave the tool in to keep air from leaking)
- Pull the rubber plug 50/50 through the hole in the fix tool, lubricate the plug with rubber cement making it much easier to insert, and push about half of the plug into the tire
- Pull out the fix tool. The plug should remain in the tire and the leak should now be 100% sealed.
- Snip or cut off any remaining plug so that the tire can roll completely flat
- Finally, air up your tire to 42psi
This video shows you the entire process
You will be back on the road in no time. And won't have to bother waiting on a tow truck, paying Tesla $300 for a new tire or driving around on a flat tire looking for a tire shop to do the same repair and charging you for the same repair. If you use this kit once, it will be worth every penny. And it works on any car so it's a great kit to have for any emergency stop.
Also, be advised you need to know the difference between a puncture and a blowout. A puncture is just that.. a nail/screw-like object in the tire.. probably picked up from a construction site or driving on the shoulder of the road. A blowout... OR a puncture that is outside of the tire tread cannot be repaired. In that case, the tire needs to be replaced completely.
