We flat tow an automatic Jeep rubiconCars that can be flat towed have some method to lubricate the differential. In a stick shift, it's splash lube of gear oil from the turning shaft. In an automatic that is approved for flat towing, the transaxle has a rear pump that is driven off of the output shaft, so towing it runs the pump.
Honestly flat towing adds normal wear and tear even when the differential is lubricated; a tow dolly is much cheaper in the long run.
Some of the Saturns are great choices for flat towing because they are cheap, light, and have the rear pump.
Flat towing a tesla even if it had lubrication would wear the drive unit. It's not a wise choice.
Nate
Or you could just use a car hauler trailer towed behind your motor home. That's what I do with my Model S.
It takes a few minutes longer to load/unload, but I've found the benefits include better mpg towing (my average mpg when from ~7 to 8mpg on my diesel pusher), the ability to back up, better protection and less wear and tear on my Model S.
When you say 1mpg better with a trailer, what’s that in comparison to?
I have a 4 door 1/2 ton Ram I flat tow. And I’ve pulled my Mercedes E550 on my 22’ aluminum flatbed. Can’t say I’ve noticed much if any difference in fuel mileage. This is with a 43’ tandem axle diesel.
With my flatbed I’m right at 70’ long. The same or slightly longer than a typical 18 wheeler. No problem going down the road, but limits the campsite possibilities.
I do agree not being able to back up a flat tow vehicle is a major pita. But I’m hitched and rolling in about 3 minutes (literally). No way you can load the trailer and tie the car down that fast.
Are either of you guy's full timing? I will be in 2.5 years. At that point I think there will be some variant of a electric class A
Winnebago is already making one but not for the rv world.
I am sure for me it will be a Diesel pusher flat towing a Jeep. But would love to have a all electric rig at some point.
Nice setup ....is it possible to charge to smart car from alternator while your diving the rv?
I've noticed an almost +1mpg gain in comparison to flat towing a Honda Pilot on a 20' flat bed with my 40' single rear axle Cummins 350 Diesel coach. YMMV. And yes, as I said, it takes a few minutes longer, but I feel it's worth it for the benefits cited. Again, YMMV.
I agree that the total length limits the campsite possibilities. IMO, that's the biggest disadvantage.
would you consider switching to the new MCI J4500e as an RV replacement?Not that I know of, or that I have heard of. We are actually planning for it’s replacement down the road, maybe a couple years. We were originally thinking something like the model 3 or even the Y but the trade war with the US has ended that. The next version of the model BMW i3 could be a contender but info is spotty at best on what it’s future is. We really like the car and a working 300 kilometre range would be more than adequate (if the do that). The dimensions are not huge but would still require going to a dual axle trailer. In the meantime we’ll stick with the smart. Lotsa fun, convertible, still kind of a head turner.
The thing with MCI and Prevost like coaches they are already Million dollar+ coaches.would you consider switching to the new MCI J4500e as an RV replacement?
https://ngtnews.com/all-electric-j4500e-motor-coach-testing-goes-off-without-a-hitch
you are correct. we don't know @Webeevdrivers circumstances either, lol.The thing with MCI and Prevost like coaches they are already Million dollar+ coaches.
But I like the direction!
Yikes 49,000 lbs!you are correct. we don't know @Webeevdrivers circumstances either, lol.
the only previous competition was this: http://en.byd.com/usa/bus/c10-electric-motor-coach/
dreams are free!!. Yah no. We barely crack six figures per year. That kinda coach is above our pay grade. Sigh.....
http://en.byd.com/usa/bus/c9-electric-motor-coach/ is less, but range tanks to 155 miles.Yikes 49,000 lbs!
We ..well I need a 35 footer with 10k towing capacity and keep the weight under 35k
