I came up with an interesting idea that you would have a boat onto which you would drive your car into.
You would then proceed to strap your car onto the boat as if the boat was a dyno.
The wheel motion would then be converted into propeller thrust in the water (could be side paddle-wheel propellers mounted onto the dyno axles or separate propellers via additional axles). If you drive a Plaid, your boat would now have 1020 hp! The shape of the boat should ofcourse have the aerodynamics and strength matching for your power range.
Some elegant solution would be needed to transfer steering motion into steering the boat, perhaps differential locks or smth maybe directly via the car's electronics.
Anyone interested in such a little DIY project? @Btr_ftw ? Anyone? Know anyone on this forum who would work on this kind of projects?
Saw something similar has already been proposed in a "drive on water" Kickstarter project:
