When you say you measured with pucks, was that with the puck on the jack or plugged into the bottom of the car?
I thought the Model 3 had a 6" ground clearance? So with this jack at 4" and the puck at 1" it should work no?
I have the Arcan hybrid jack and with the puck plugged into the bottom of my M3, there is slightly less than an inch of clearance between the saddle and the bottom of the puck. Note that the Arcan saddle sits at 4 inches at its lowest point.
