Florida HPWC Wire Hanger Problem
Discussion in 'Florida' started by aviators99, Jun 30, 2013.
Tags:
  1. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    I assume that most people's garages in Florida are like mine, and not drywall but CB. The screws and installation materials that come with the wire hanger will not work at all in this situation.
  2. ClearwaterBchSteve
    ClearwaterBchSteve P445 / VIN 1794
    Clearwater Beach, FL
    You'll probably have to drill holes and use concrete anchors. I've had to do that for a number of mounting jobs at our home which is also block. (hose bibs, etc.)
  3. TampaLiam
    TampaLiam Secret Agent
    Tampa, FL
    Also note that there has been some concern online that the tabs could lock the unit in place - but are not accessible once installed. If tesla has not modified the design, this requires you to have access to the back side of the device to remove once installed... which is not possible on CB.
    Solution, if this is still an issue, is to file down the tabs. Gravity will hold it in place sufficiently.
  4. aviators99
    Thanks. I already removed the tabs, but then realized the screw problem...
  5. NigelM
    NigelM Recovering Member
    Northern Virginia
    It would be a step forward if I actually received mine.....:frown:
